Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
drag link HELP!!!
(85 toyota pick up 4x4) i installed an adjustable drag link n now da right turn is wider den da left. HOW CAN I FIX DAT???
| Sponsored Links |
#2 (permalink) | |
Have it aligned.
Or just check your toe. DAT is how you feex eet.
__________________
Need that hard to find part? Nix99 Used Toyota and Lexus parts! Quote:
#3 (permalink) |
#4 (permalink) | |
im sure a shop can do it no problem
__________________
#5 (permalink) | ||
Location: Selling turnips on a flatbed truck, I 15N @ 79S
this kid 14 ?
wait, Hawaii...there we go
__________________
^Say GO DJ..Uh thats my DJ The Blue Biche 91 4x4 p/u 22re--elbow mod, 500ff's. BFG A/T ta KO's. Smokey the Bear I Work on my gas tank while smoking a cig...Sue me Dad- 1999 4runner base 2x4, 2.7, 5speed, 52k, cherry. Chat with meeee Quote:
Quote:
UltimateYota |
#6 (permalink) |
You don't need to go to a shop, you have to ADJUST the ADJUSTABLE drag link. I had the exact problem, left turns were no problem and the rights were crazy wide. Just play around with it till it works right.
__________________
nothin says buck, like a toyota truck Last edited by 85TurboRunner : 08-07-2008 at 04:52 AM. |
#7 (permalink) |
Sponsoring Member
Adjust the adjustable drag link until it is adjusted to adjust your steering adjustment correctly. Is there a reason you installed this adjustable drag link?
Is English still required in Hawaii? ![]() ![]()
__________________
WabFab Off-Road, LLC www.myspace.com/wabfab 6th Annual South East 4Runner Jamboree, May 22-25, 2009 WabFab Off-Road Salvation Army Online Kettle |
#8 (permalink) | |
English? Is that some new form of Ebonics? I don't think I have heard of English before.
__________________
#9 (permalink) |
#10 (permalink) |
[quote=waskillywabbit;50893265]Is English still required in Hawaii?
![]() YAH WE SPEAK ENGLISH HEA... ONLY DA PURE HAWAIIANS SPEAK HAWAIIAN LOL OTHER DEN DAT ITS ALL ENGLISH Last edited by eighty5toyota : 08-07-2008 at 09:29 AM. |
#11 (permalink) |
On the adjustable drag links, they have one the rod ends set up with the pre-load spring towards the inside end of the link on both ends. In the stock drag link you have one spring inside and one spring outside. Whey does that make any difference you might ask? Well when you turn one direction (like left) you are pulling on the drag link and have solid metal to metal connection for the ball suds on the pitman and steering arm and the drag link. Turn the other way and compress the two springs and now you have no solid connection inside the drag link. So the trick is to crank down on the rod ends of the drag link as tight as you can get them. You can read about how I adjusted mine on the web page below:
- http://www.4crawler.com/4x4/4R_suspension.shtml#PhaseI With the stock drag link, you have balanced steering left and right because there is always a spring on one end and a solid end on the other end no matter which way you steer. With the adjustable drag link, you either have solid-solid or spring-spring depending on which way you turn. It is sort of a design flaw in those adjustable drag links. They give you two identical rod ends while they really should make two different rod ends like Toyota did for the stock drag link. This is a writeup for aligning crossover steering but would apply to the stock push-pull steering as well: - http://www.4crawler.com/4x4/CheapTri...html#Alignment Basically, center the steering box so it is in the middle of its range of travel the adjust the drag link length to get the front tires straight ahead.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs. r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| drop drag-link | Magoo | Axles/Suspensions/Tires/Wheels | 4 | 10-16-2008 08:25 PM |
| adjustable drag link | rockrawlerzuk | Axles/Suspensions/Tires/Wheels | 1 | 04-15-2007 09:00 PM |
| Adjusting drag link | paxil4x4 | 84-85 Trucks & 4Runners | 3 | 12-02-2006 05:07 PM |
| Drag Link failure | joshik | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 10-12-2005 11:22 AM |
| Major drag link slop | yotafreakshow | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 07-27-2004 11:17 PM |
