'85 Pickup Lift
Old 06-04-2008, 07:32 PM
Foolonastool's Avatar
'85 Pickup Lift
Anyone got any advice on a reasonably priced lift for an '85 pickup? I most likely wont take it offroad much and a smooth ride doesn't really matter too much to me, my stock shocks are pretty much rusted together. Basically riding on a solid piece of steel with wheels.
I'm looking at this one, just because it's cheap. Anyone have experience with skyjacker lifts?
http://www2.partstrain.com/partlisti...Suspension+Kit
Old 06-04-2008, 08:04 PM
4x4YOTA's Avatar
I used pro comp on my 82 and was very happy I used pro comp front springs, downey 4" shackle(1"longer than stock). and the rear stock springs with longer shackle (3" longer than stock) (and small block to level). and used 12" travel procomp shocks. ended up with about 4" total lift, as for steering I used pro comp 4" drop drag link. spent a total of about $400-$500 in the end
front springs $130 (pair)
shocks $130 (set of 4)
drag link $90
shackle $50 (each)
Old 06-04-2008, 08:17 PM
So I can get a pretty decent lift pretty much by just adding some leafs?
By the way, I see that you have a cherry bomb on your 94, how do you like the sound of it? I was thinking about getting one, I'm running straight pipes cut off right after the cat right now and I know that's not going to fly for long living in the middle of a suburban neighborhood. Thing sounds like a ing tractor.
Old 06-04-2008, 08:21 PM
4x4YOTA's Avatar
the cherry bomb is great it has a nice deep throaty sound and isnt to loud and not ricey I also had one on my 82 22R and it was a bit louder but I also didnt run a pipe after it
Old 06-04-2008, 08:22 PM
Hayes's Avatar
not by adding leafs, springs are more leafs (sometimes) with a greater arch. Get a kit and make your life a lot easier. I use a procomp lift 3'' in front 4'' in the rear. Came with shocks and flexes suprisingly well for a 400 dollar lift. Get shackles while you are at it.
Old 06-04-2008, 08:24 PM
4x4YOTA's Avatar
thank you thats exactlly my point it really is a great kit
Old 06-05-2008, 06:02 PM
Nebrkid817's Avatar
My advice would be to check out rough country they seem to have pretty good deals on suspension lift kits
Old 06-23-2008, 07:53 PM
0101's Avatar
where did you guys get your lifts?
which one of these would you recommend?
http://www.4wheelparts.com/Lift-Kits...5491&t_pl=1808
Thanks!
Old 06-24-2008, 03:48 PM
baseballchamp157's Avatar
Id go with roughcountry. I got a 3in for my 85 and it was simple to put on. You can either go with leaf on the front and blocks on the back or for a little more money you can get leaf front and back. But if you dont care about ride id go with the cheaper blocks on the back.
Old 06-28-2008, 08:46 PM
weekndwarrior's Avatar
I was curious about the same thing. I have an 85 4runner (solid axle) and wanted to be able to get 35's under it. I would like to keep it under 4" of lift and am not afraid to trim some fender but it needs to be street legal because I dont have a trailer or tow rig. Possible?
09-04-2015 09:27 AM
akaphilly
07-09-2015 02:18 PM
God's Bounty Hunter
07-08-2015 12:54 PM
MTLroadierunner
07-06-2015 12:17 PM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: '85 Pickup Lift
