85 4runner Auto Trans shifting problems
I have a 85 4runner and it seems like when you take off its in second then doesnt want to shift to 3rd untill u hit the overdrive button then goes to overdrive when you hit again it comes back to third. who i got it from told me that the soleniods had been replaced i dont have any idea what could do this . . the check angine light stays on as well was also told that the engine computer has been replaced and the lights still stayed on . . idk if that has something to do with it. can any one helpppp???
thankss
SHAWN
thankss
SHAWN
I would think it best to run the codes on your engine first. After you have determined why your check engine light is on ( and repaired the problem ) you will be in a better position to diagnose the tranny.
With computer controllers it's always-"junk in junk out".
If it's blinking you have stored codes in the ECT unit.
To get it to flash the codes, you need to ground the small square plug on driver fender.
switch ignition on without starting and OD must be on.
voiddweller
19
05-02-2016 09:10 PM
