Vented rotors..
Vented rotors..
So I bought some vented rotors to go with my front axle rebuild and to get rid of the soild ones cause I have the bigger v6 calipers.. the only thing is theres no 2 holes for the 2 14 mm bolts to go in them? Im I sposed to drill them or just assume the wheel studs will keep it on? btw went the the stealer ship 7 dollars for one wheel stud. thanks for the advice.
i got drilled and slotted rotors that are workin great for me so far, but everybody flamed me for it askin me why i didnt go with the fj60 rotors, i still dont know whats so great about them
Well they were 20 bucks a peice, and they vented. I saw on trail gear you can use them 82 to 90 or something. soo would you say I should drill out the 2 small holes for the 14 mm bolt to bolt it to the wheel hub? since it dosnt have it?
ok so can I get the SFA rotors at the local parts store or do I gotta go through trail gear? will the fj60 ones work cause they have them in stock there like 20 more ?
ok I ordered them today I Mustive gotten the wrong year or something... I tryed 07 fj rotors and they didnt line up at all and only had the six holes. can someone tell me what year I need to get them off of?
yah I did , but I found it after some googleing. Needs to be put up on maybe a how to on here cause every where I seen it was just fj rotors no dates.
ok I got a little carryied away grinding, and ground out the circle so it would fit on the wrong side of the wheel hub.. I didnt have too anyways did I just make a paper weight or can I still use it? reason I ask is I dont wanna screw up the bearing from it wobbleing or something
it is listed here and on multiple other forums about putting vented fj rotors on our trucks. 5 mins worth or research would have taken care of all your problems. multiple people in this very thread even told you what to get....fj60 rotors. about your last post, i have no idea what you are talking about.
kawazx636
10-06-2021 03:03 PM
coryc85
12-05-2015 08:42 AM
gyroscope7
7
09-27-2015 08:39 PM
