Pre 84 Trucks 1st gen pickups
Spacers
Old 05-25-2010, 02:41 PM
Nimyad's Avatar
Spacers
so i'm goin to switch in the wider rear axle (i need spacers up front cause i hit the leaf springs and box when turning) so i'm goin to match the width up front. so my bud told be you can take stuff off an ifs and replace parts of the live axle instead of using spacers and you'll still gain 3 in total width. has anyone does this? what all do i need from the ifs?
Old 05-25-2010, 02:49 PM
xxxtreme22r's Avatar
sounds like he's talking about using the rear end from an IFS truck as the front axle. Doable? IDK, anything is possible with the right tools, knowledge and fab skills.
Old 05-25-2010, 03:07 PM
Nimyad's Avatar
no he was saying you can take the outer assembly from an ifs and put your stock hubs in it and run it on the original solid front axle.
Old 05-25-2010, 03:40 PM
slacker's Avatar
yes .. the 86-95 IFS hubs are interchangeable ... and wider .. and match the width of the 86-95 rear axle housing ..
Old 05-25-2010, 03:43 PM
Nimyad's Avatar
ok. so i just get the ifs hub assemply. do i run those calipers and rotors or what?
Old 05-25-2010, 03:49 PM
slacker's Avatar
bolt pattern is the same .. so all of your old parts will work ..
i might suggest the up grade though ..
Old 05-25-2010, 03:52 PM
Nimyad's Avatar
like the v6 calipers and vented rotors? if i pull ifs hubs from a v6 pickup isn't it the same thing.
Old 05-25-2010, 05:34 PM
slacker's Avatar
yes vented landcruiser rotors and V6 IFS calipers ..
IFS truck rotors are not vented .. they are solid
I have them on mine .. check out my current build in my sign.
Old 05-25-2010, 07:00 PM
Nimyad's Avatar
ok. thank you. trying to decide if it's better to do all that or just get spacers
Old 05-26-2010, 06:29 AM
slacker's Avatar
spacers are what ? $65.00 and about 1/2 hour to install ...
Old 05-26-2010, 06:37 AM
waskillywabbit's Avatar
All this is detailed in several threads on here as well as the Pirate Toyota FAQ.
Old 05-26-2010, 03:50 PM
Nimyad's Avatar
ya but i want to do it the right way and the stronger way so that's why i was looking into this
Old 05-26-2010, 03:53 PM
SpecialScottie's Avatar
So whats the point of buying the sky kit if you can just use IFS hubs to gain the width?
Old 05-26-2010, 04:02 PM
Nimyad's Avatar
i would imagine it might be easier but parts from a junkyard would be a lot cheaper and probably worth the extra effort
Old 05-27-2010, 09:51 AM
Fossilized
Staff
dropzone's Avatar
using the IFS parts to widen the front SA is not just slapping the parts on:
http://www.sky-manufacturing.com/new...uct.php?id=127
http://www.pirate4x4.com/forum/attac...postid=1649941
http://www.pirate4x4.com/forum/showt...9&page=1&pp=25
http://pirate4x4.com/forum/showthrea...15#post2423615
some of this should help you out
4x4YOTA
08-23-2016 09:08 AM
89YodaRunner
09-30-2015 02:18 PM
JookUpVandetti
09-30-2015 08:58 AM
4runnerFireman
09-29-2015 06:24 AM
crash813
09-27-2015 07:15 AM
Quick Reply: Spacers
