| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Plate on back of 22R?
#2 (permalink) |
Thats for EGR i believe. Um its kinda hard to get to not many people mess with it you can try it but its prolly going to be a son of a........
__________________
My current: 1986 Toyota 4runner SR5 EFI 4cyl 2.4L 22RE 5-Speed 242,000 Miles 95% Stock __________________ (Still working on restoring her) My old: 1988 Toyota 4runner SR5 EFI V6 3.0L 3VZ-E 5-Speed 302,000 Miles All stock (sold)______________ (Was my fastest truck i miss her...) My old: 1989 Toyota 4runner Non-SR5 EFI 4cyl 2.4L 22RE Automatic 231,000 Miles (sold)______________ (was my quietest and slowest yota.) |
#3 (permalink) |
'm gonna say probably NO. when I took my head off, I left that intact until I had my head laying on my work bench. As you know, it is such a tight squeeze, even if you can get it off, I don't know how you can honestly be sure you would have it all back together right.
I'll post you a pic of mine......
__________________
1992 4x4 shortbed /22re/auto/192,000 miles--original owner(rebuild in process) 1988 SR5 4runner /V6/5 speed/248,000 miles/bought April 2009/***UNDER CONSTRUCTION*** 2006 SR5 4runner (the wife's)....still being paid for... >>>>***Check out My SLOOOOOOW Re-build Thread***<<<< http://www.yotatech.com/f116/92-toy-...-start-188472/ |
#4 (permalink) |
here ya is......
[IMG] [/IMG]
__________________
#5 (permalink) |
Can it leak oil? Found a lot of oil on top of my transmission when I pulled it out. the transmission is out right now and was wondering if I had to get at that plate from underneath above the clutch. If it can't leak oil then the oil is from my rear valve cover half-moon (I hope...).
#6 (permalink) |
no oil in there, i believe its either exhaust from the egr tubes or coolant running through it. Definitely not oil.
__________________
"There should be no discussion of significant mods until you do the first important one - tighten the nut behind the wheel." 1987 Toyota Pickup 4X4 5sp Manual (flatbed) 22R Carb 1992 BMW 535i Auto(E34) 1994 Chevy Cavalier Wagon Auto (RIP) 1985 Ford Bronco 4X4 Auto (RIP) 1983 Ford Bronco II 4X4 Auto (RIP) 2001 Hyundai Elantra 5sp Manual (14.3@95MPH 1/4mi) (RIP) 1996 Pontiac Grand Am SE Auto (RIP) 1982 Chevy C20 Pickup 2WD Auto (RIP) 1977 Toyota Celica GT 20R EFI Auto (RIP) |
#7 (permalink) |
Thanks everyone! I'm going to slide my tranny back in tonight (easier said than done). Then sleep a whole lot better with my new real seal & clutch kit. I'll get to the valve cover & half moon later.
#8 (permalink) |
did you replace the front seal on the trans? i would while you have it apart
__________________
#9 (permalink) |
it can leak coolant. not oil.
its an egr cooler. and yes, it can be removed. it is just a PITA! and u need a flex head ratchet wrench. haha
__________________
86 4Runner, 2" Body Lift |
#10 (permalink) |
finding a gasket for it might be a PITA too. As well as cleaning off the old one.
__________________
#11 (permalink) |
front seal on the trans, how involved is it?
#12 (permalink) |
easy like 6-8 bolts take the dust cover off and pull the seal. no harder than the rear main
__________________
#13 (permalink) |
OK, I'm sold. I'll wait to install trans until I get the seal. BTW... It's a straight forward 2WD W-Series Trans.
#14 (permalink) |
Yeah coolant runs through there. If you had a bunch of oil on top of your tranny it's probably from the rear half-moon gasket on your head. That rear one likes to leak. Replace the gasket and use some RTV on it.
__________________
Zach '83 Shortbed 4x4 L52HD Rebuilt & Mostly Stock |
| Tags |
| 1982, 1987, 22r, carburetor, engine, head, miss, pickup, plate, rear, seal, toyota |
