Plate on back of 22R?
'm gonna say probably NO. when I took my head off, I left that intact until I had my head laying on my work bench. As you know, it is such a tight squeeze, even if you can get it off, I don't know how you can honestly be sure you would have it all back together right.
I'll post you a pic of mine......
Can it leak oil? Found a lot of oil on top of my transmission when I pulled it out. the transmission is out right now and was wondering if I had to get at that plate from underneath above the clutch. If it can't leak oil then the oil is from my rear valve cover half-moon (I hope...).
Thanks everyone! I'm going to slide my tranny back in tonight (easier said than done). Then sleep a whole lot better with my new real seal & clutch kit. I'll get to the valve cover & half moon later.
Yeah coolant runs through there. If you had a bunch of oil on top of your tranny it's probably from the rear half-moon gasket on your head. That rear one likes to leak. Replace the gasket and use some RTV on it.
Jun 1, 2021 01:51 PM
[/IMG]
