Pre 84 Trucks 1st gen pickups
Oh no...t-case output is loose!!!
Old 08-17-2014, 03:24 PM
craftsmanracer's Avatar
My t-case output is loose!
Is it as bad as I think it is?
Any chance you know the torque that should be applied to the main nut on this shaft?
I have to drive a hour tomorrow? Wouldja trust it?
http://vid203.photobucket.com/albums...ps75ad12de.mp4
Old 08-17-2014, 03:45 PM
slacker's Avatar
90 ft/lbs ... and then "staked"
check your out put bearing
Old 08-17-2014, 04:36 PM
millball's Avatar
I think the correct torque is only 90fp. Then staked.
Take the flange completely off and degrease the splined parts and coat them and the threads with locktite before reassembly.
Great time to change out the seal as well.
Common for the flanges to get loose on high mileage trucks.
Mine did. I retightened them. My bearings were still good.
Edit: My '83 FSM says 80 to 101fp.
Old 08-17-2014, 05:19 PM
millball's Avatar
Unless you have suffered immediate output bearing failure, it did'nt get loose overnight.
If you have no new noise or vibration, you can probably drive it, if you take it easy.
Old 08-17-2014, 05:27 PM
Thanks guys, I just got under it and tightened the stake nut.
It was moving around in it's staked notch on the shaft. (I could wiggle it with my fingers)
I tightened it to 90 ft-lbs, re-staked the nut, and it seems good to go.
I do need to replace the seal though, it is throwing oil everywhere.
Members like you guys^^^ are what makes the forums great. I came in all panicked and convinced that my t-case was 'effed, and it turned out to not be that big of a deal.
thanks!
Old 08-18-2014, 09:39 AM
Batousaii's Avatar
thanks!
I would, seals that can be done with the unit in place are rather easy. I've had my drive shaft in and out more times than I can remember... it's simpler than you think.
My T-case nut came loose too a while back. Like yours, it was floating around on the stake. It was an easy fix... just download the manual and go from there.
Old 08-18-2014, 10:20 AM
gillesdetrail's Avatar
I think these t-cases are pretty tough, when I broke my front driveshaft it hit the t-case and made a big hole in it, I drove home 4 hours with no oil in the case with no problem, just a little whinning, it still shifts fine and sounds good.
Old 08-19-2014, 08:38 AM
83Toyota88's Avatar
I replaced my T-case output seal with a Marlin seal. Very nice product. I was slinging oil everywhere like you.
justdifferentials
14
06-11-2017 08:36 PM
Davebarbier
11-03-2015 03:28 PM
Rerun
3.4 Swaps
10-01-2015 12:24 PM
hiluxinargentina
09-30-2015 11:12 PM
sonorn67
09-19-2015 05:39 PM
Quick Reply: Oh no...t-case output is loose!!!
