Pre 84 Trucks 1st gen pickups
Dash light help 1980
Old 05-27-2012, 12:22 PM
jastamjas's Avatar
I have a 1980 4x4 and the dash lights dont work and the blower motor doesnt work. I checked the fuses and they look fine
Old 05-28-2012, 03:04 AM
suncomb1's Avatar
First check the dimmer switch operation on the left side of the dash, then pull the gauge pod and check the bulbs and the condition of the bulb holders. Next check the circuit ribbon condition for corrosion or damage. If you see any corrosion around the circuit ribbons try to clean it off with CRC Electrical contact cleaner. Check your wiring at the gauge pod plugs for damage. If you have a tilt wheel, they are famous for causing broken wires so check for damaged wires going in the tilt steering area.
Old 05-28-2012, 08:53 AM
jastamjas's Avatar
I got the dash lights working. It was the dimmer I cleaned it up and they work now. Thanks for the help.
ashersullivan88yota
01-18-2022 05:37 PM
ghostmoney
01-28-2018 11:42 AM
AkitaDog
09-01-2015 08:05 AM
ViperTT
08-14-2015 05:27 AM
Johntom240
7
07-13-2015 12:18 AM
Quick Reply: Dash light help 1980
