Pre 84 Trucks 1st gen pickups
cracked spring hanger
Old 09-16-2008, 09:43 AM
4x4YOTA's Avatar
ok I was out working on my 83 and noticed my spring hanger is cracked on the front driver side above the bolt. I was looking int a new hanger from trail-gear but I was curious to know how much lift it will give me. I dont want to go any higher than 3-4" of lift and I already have 2" lift shackles and I was thinking of getting some 2" lift springs from NWOR or maybe selling my shackle and buy a shorter set and get the trail-gear 3" springs. what do you think? I want as litttle amount of lift as possible cuz I just want to be to high enough to clear for high steer
Old 09-16-2008, 09:48 AM
4Crawler's Avatar
Most of the spring hanger kits lower the front mount an inch or so from stock, so around 1/2" of lift. This works well with a longer spring shackle since you negate part of the axle tilt the shackle gave you. I dropped my front hanger 2.5" and run a 3.5" longer than stock shackle and that gives me most of my lift up front, springs are nearly flat.
Old 09-16-2008, 11:22 AM
4x4YOTA's Avatar
what about clearing high steer?
the guys at trail gear said I need at least 3" of spring lift to clear it?
any pics of your drop hanger?
Old 09-16-2008, 11:25 AM
Fossilized
Staff
dropzone's Avatar
the guys at trail-gear are correct
Old 09-16-2008, 11:39 AM
4Crawler's Avatar
Pictures on the web page below:
http://www.4crawler.com/4x4/CheapTri...ringHangerDrop
And a dropped front hanger adds clearance for the high steer drag link and tie rod.
Old 09-16-2008, 12:57 PM
4x4YOTA's Avatar
ok so I priced it out and I think I am going to go with Trail gear hanger and 3" front springs and get a shorter shackle
punks_is_4x4
05-31-2016 06:03 AM
RickyD
10-02-2015 07:53 AM
Streetrod19772000
09-10-2015 06:22 PM
justdifferentials
09-05-2015 06:52 PM
joeynational
09-05-2015 01:54 PM
Quick Reply: cracked spring hanger
