Tool Time Discussions here pertain to the use of tools you use while fabbing and wrenching in the garage
what works better than PB Blaster?
Old 11-18-2008, 06:00 AM
desertcox05's Avatar
another + for kroil. also marvil mystery oil is very good, it comes in a gallon can and you can buy it at a.z and advance. read the can too good for lots of other things.
Old 11-18-2008, 06:26 AM
rdlsz24's Avatar
My dad and I have had good luck with this stuff:
It freezes the rust so it gets brittle and breaks loose.
Rob
Old 11-18-2008, 07:08 AM
GSGALLANT's Avatar
At the nuke plant where I work, the shops use methyl salicylate (oil of wintergreen). I've used it a few times, and a little does go a long way (you typically apply it to the nut/bolt with a small syringe). It is expensive, though. Does it work better than PB Blaster? Not sure... I've had good luck with PB Blaster as well, but wintergreen seems to work a bit faster.
ashersullivan88yota
01-18-2022 05:37 PM
sandyota
02-04-2021 11:16 AM
09-04-2015 09:27 AM
crashburnoveride
07-10-2015 06:39 AM
madxman21
07-09-2015 10:26 AM
Quick Reply: what works better than PB Blaster?
