| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
What Welder Should I Get?
__________________
Weekend Rig - 85 SR5 Pickup: 4x4, 5-Speed, 22RE, 35/12.50/R15 Mud Brutes Custom built box with big stepside fenders, About 3" body lift Pioneer CD player (iPod Controll) with 10" sub woofer Current Daily Driver - 2000 Corolla
Alpine iDA-X303 Deck Alpine 12" Type X Subwoofer in Ported Box |
#2 (permalink) |
I got a lincoln flux-cored wire welder, and it's great for smaller projects with thin metal. The stick welders are more for the thicker metals. It just depends on what you are going to use it for.
#3 (permalink) |
You can do a lot with a 110 welder but a 220 will give you more flexibility. Yup - wire feed is good. A lot of companies have a starter welder that is 110 and comes with a good wire brush and different types of welding wire.
__________________
"Turtle" - Green 94 4Runner Looks like one and about as fast JDM altimeter/clinometer, 2002 Sport wheels, 265/75r16 MT/R, , OME stabilizer, BJ Spacers, Cruiser Coils, removed sway bars, rattle can paint for all that peeling clearcoat! Lockright front and rear. |
#4 (permalink) |
I wouldn't get anything less than a 220v. Buy your last welder, first.
Once you've got a welder, a bottle, gas, a mask and a spool of wire you will average around $1000 for a decent new welder. A welder is absolutely the last place to be cheap. I have a Hobart 187. It's great. It can do anything. Thin to thick, aluminum to steel. The welder was $820, the tank was $75/yr lease (too expensive for me to purchase my own right now, 300cu-ft) and $54 per fill. The mask was $30, simple flip down. Auto-Darkening is nice, but they can and do mess up from time to time. I don't want to take the risk. Wire, an 8" spool which weighs about 14lbs was $16, it will last you a long time. You can get smaller 4" spools as well. It can run on gas (75% Argon, 25% CO2) or it can use flux-core. I hate flux-core, too much spatter. It's good for dirty metals though, with rust. Welding rusty metal with gas is damn near impossible. Flux-core behaves better outside too, wind and such. It's hard to weld using gas when there's a breeze. I had the fan in the shop blowing at me because I was sweating bullets and just playing around with my welder (I'm still learning too, btw) and I couldn't get a good bead going. I don't recommend using a 110 welder for frame work. It can be done, but you really need to know what you're doing to make it work. Stick is a much harder technique to pick up, and also to be good at. I'm not a fan of stick welding for anything small, or anything automotive. But if you need to join 1" plate or build a tank, or weld pipe. I know where you're coming from, so I'm not saying run out and spend thousands... but it's just better to get a good 220 welder to begin with. |
#5 (permalink) |
You might consider taking a welding class at your local adult ed. place if one is offered. You'll get a taste for the various welding techniques and machines and find out what you like best and what features are best for the type of welding you plan to do. I did the same and it was worth the time and money spent.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| no welder and 63"s | DeepSeaSnake | 84-85 Trucks & 4Runners | 3 | 09-19-2007 08:47 PM |
| Looking at this welder: | ClemsonToy | Tool Time | 23 | 10-30-2005 12:30 PM |
| I need a welder! | getitdone | Tool Time | 20 | 07-16-2005 08:39 PM |
| What welder to get? | corvettelvr73 | The Fab Shop | 8 | 10-03-2004 07:02 AM |
| Looking to buy a welder! | Optimus | 95.5-2004 Tacomas & 96-2002 4Runners | 73 | 09-22-2003 05:58 PM |
