Tool Time Discussions here pertain to the use of tools you use while fabbing and wrenching in the garage
tube bender
Old Jan 13, 2007 | 04:50 PM
burtonsoldier's Avatar
tube bender
how many of you out ther have a bender for tubing. ive wanted one for a while and have always seen these ones at harbor freight does anyone have one like these, and how hard is it to bend with it. any feedback would be cool. late.
Old Jan 13, 2007 | 04:51 PM
oh ya i forgot the link , here is the bender i was talking about.
http://www.harborfreight.com/cpi/cta...emnumber=31980
Old Jan 13, 2007 | 04:57 PM
jjrgr21's Avatar
don't buy it, i bought this one http://www.harborfreight.com/cpi/cta...emnumber=32888
and either i suck at using it, or i'm not getting something.
for slight bends it's at best ok, but for steep bends it kinks.
don't waste your money, i started using "weld L's" you can get them in 45 and 90 degrees, alot easier than bending.
Old Jan 13, 2007 | 04:58 PM
jjrgr21's Avatar
that one may work ok, but i've never used it.
Old Jan 13, 2007 | 05:03 PM
CJM's Avatar
CJM
You wont be bending much, slight bends are ok-sharp ones it kinks with those kinda things. you need a quality bender and they dont come cheap.
Old Jan 13, 2007 | 05:19 PM
pepsibluefloat's Avatar
I have that same one. It kinks pretty bad, the best way i found to use is it to slightly move the pipe after a few cranks on the jack and move it back and forth along the bend until you get the desired bend or jsut heat the tube..
Old Jan 13, 2007 | 05:37 PM
jjrgr21's Avatar
i've been using the weld "L's" with good results, i've given up on the kinker
Old Jan 13, 2007 | 06:52 PM
waskillywabbit's Avatar
That POS you guys are looking at is a PIPE bender...and that is a stretch...a good tube bender setup is going to cost you $500 plus and tubing dies are $250 EACH.
Pipe and tube are NOT the same thing at all.
If you want to bend tubing, invest in a TUBE bender.
www.tricktools.com
Old Jan 13, 2007 | 11:37 PM
T-town's Avatar
I have a JD squared model 3 bender. I like it and it isn't too pricey. The bumper that I made in the FAB section took maybe 30 minutes to bend, super easy to use.
Old Jan 14, 2007 | 10:09 AM
reggie 00's Avatar
Nice find.
I have a bunch of hyd rams at Pop's house we might even be able to convert over. Defiantly putting that on the short list.
Old Mar 12, 2009 | 03:08 PM
scuba's Avatar
Old Mar 12, 2009 | 03:39 PM
Fink's Avatar
Spammer gone - back on topic!
Fink
TheBFA
Feb 15, 2020 06:55 AM
Badlander
Oct 10, 2015 08:05 PM
mreagen
Oct 5, 2015 04:27 PM
dguzzi
Sep 3, 2015 08:48 AM
