Tool Time Discussions here pertain to the use of tools you use while fabbing and wrenching in the garage
Plastic Welder vs. Epoxy/Adhesives
Old 07-23-2014, 12:28 PM
dromomaniac's Avatar
Hey, looking for first-hand info on plastic welders. These are one of those tool-types that I keep finding myself wanting/possibly needing for work.
Are they worth it?
What can they do that can't be done with epoxies or other adhesives?
Can they handle PVC?
Oh, and many things I would fix using this tool would need to withstand moderate exposure to sulfuric acid and possibly other acids. So urethane "welding rod" would be less than ideal--still doable for some things, but less than ideal.
Thanks!
Old 07-23-2014, 11:37 PM
wyoming9's Avatar
Red face
Only you know just how much of a need you have.
Have you priced out a good system not like a Harbor fright plastic welder package.
I had thought of going this route one can buy quite a lot of expoy and glue compared to a set up to weld plastic.
My question are you spending your money or someone else`s
Old 07-24-2014, 08:08 AM
Well, I've looked over what Northern Tool has (and Harbor Freight ). I would prefer that my money not go into this--which would mean I need to sell the idea to the boss.
But, the more I look into it the less useful it seems. I work for a small firm and $3k for a plastic welder is not going to happen. More than that, I just don't see a point unless we end up dealing with huge plastic holding tanks--even then, a HF type deal would be preferable for cost and portability. Most plastics I deal with are PVC, PP, and Acrylic, all of which can be welded with solvent-adhesives.
The reason I was interested is that epoxies and whatnot can be tricky to apply and often require long set times. In field work this is nearly always an invitation to shoddy jb-quick work.
ashamsuddin
17
01-13-2023 03:17 AM
TheBFA
02-15-2020 06:55 AM
Dale Johnston
11
10-31-2015 10:22 PM
whiteyota93
09-29-2015 02:31 PM
mtrdrms
09-26-2015 07:12 AM
Quick Reply: Plastic Welder vs. Epoxy/Adhesives
