| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Harbor Freight Portable Air Compressor Review
#2 (permalink) |
Interesting, I wonder how that compares with the MV-50 compressors I run?
Seems like it takes a lot less time to inflate from 11psi to 30, but then, I run two in tandem, hardmounted, with the bumper as a tank. I too believe in redundancy! The things I started not liking about CO2 were: 1) I ran out right when I needed to fill one more tire, or two more. 2) Not that convenient to fill. Or it seemed that way. Nothing in Moab, and the place near me usually has tanks to swap, but not always. 3) When sleeping in the back of the truck, it was one more thing in my way. And more weight. 4) I needed a compressor anyway for the ARBs. I would not want to plumb CO2 for them, though you could. If you ran out, you would have neither air NOR lockers. Not good. The drawback to the electric compressors are: 1) requires a couple 30A breakers. They draw a lot. I have a high cap. alternator now, and two yellow top batts, so not a big deal. 2) Both relays in the compressors died. No matter, I am controlling them with external relays anyway, so these were redundant. I simply removed them and soldered the wire in its place. Replacement 30A automotive relays are as common as Checkers/Kragen or Radio Shack.
__________________
-Bill Red Chili II: 1987 SASed 5VZ-FE 4Runner with more stuff than I can afford. Not that that makes me unique 'round here. Shadowfax: 1993 minitruck. Getting the Engnbldr full meal deal. Hunting truck and DD! Bio Page Last edited by Red_Chili; 05-12-2008 at 12:02 PM. |
#3 (permalink) |
I have the same compressor. I tried using it to fill up a portable air tank. When it got to 90 psi the thing broke. The motor still worked but the piston inside was toast. Its made of plastic. I suppose if its used for tires only it would be fine.
__________________
1985 4runner 22re 5spd. |
#4 (permalink) |
Mine are going on three years, still working, filling the bumper/air tank.
Just luck of the draw.
__________________
-Bill Red Chili II: 1987 SASed 5VZ-FE 4Runner with more stuff than I can afford. Not that that makes me unique 'round here. Shadowfax: 1993 minitruck. Getting the Engnbldr full meal deal. Hunting truck and DD! Bio Page |
#5 (permalink) |
i have a similar one from harber freight, altho mine will only fill my 31x10.5 tires to about 18 psi all tires with aobut 10minutes of running, its not to bad i just use it to get me home its not a long drive , i run like 13psi when im offroad in the dessert (dunes). i acutally use it as my main air compresser in my truck just put it behind my seat ,
#6 (permalink) |
Hmmm, then it ain't anything like the MV50. Much better performance even with just one MV50.
__________________
| Tags |
| 115, 125, air, compressor, compressors, dunes, fill, freight, fright, harbor, harbour, increase, portable, pressure, review, reviews, small, tank |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| looking to buy a portable air compressor | weakyota91 | General Vehicle Related Topics (Non Year Related) | 0 | 05-08-2007 10:25 AM |
| Portable Electric Air Compressor | mastacox | Offroad Tech | 9 | 07-13-2006 12:25 PM |
| How should I mount my portable air compressor? | yoda92 | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 12-08-2005 09:30 AM |
| Harbor Freight? | rondo221 | 95.5-2004 Tacomas & 96-2002 4Runners | 20 | 07-09-2004 03:29 AM |
| Best 12V Portable Air Compressor? | BT17R | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 03-25-2003 02:44 PM |
