simple Q re: ADD to manual hub swap
when you remove the gold dust cap on the ADD hub, there is a bolt underneath. does it need to stay? does it matter if it does or does not?
The .pdf has it installed....and so does a picture from the service manual...Also in this link... https://www.yotatech.com/forums/show...in+hub+rebuild
And the .pdf to make it easier to find....http://www.yankeetoys.org/Documents/AisinHubs.pdf
I just did an ADD swap and I thought it helped to retain the cv axle from pulling out or just moving around so much--I know I had everything apart and couldnt remove the axle until I remembered to remove that bolt, if it is the gold 12mm bolt your talking about. I may be way off on this, but it's just an idea
I replaced my CV shaft on my 90 4runner 6 weeks ago and when we pulled that dust cap off, the gold washer/bolt on the end of the shaft was what was holding my shaft in place. We dug further and found that the C-clip that snaps onto the little groove in the splines was very loose and easy to take off.
So dont permanently remove that washer and bolt, besides, it's only a few grams of weight, nothing major.
