1985 4runner towing?
Old Nov 8, 2006 | 08:03 PM
mercury89's Avatar
Smile 1985 4runner towing?
I have the opportunity to purchase a 1985 4runner with the 4cylinder and the manual transmission for a couple hundred bucks. Would I be crazy to think I would be able to tow a small (2000lb) boat with this truck?
I love the old 4runners but I would like to know more about its towing capabilities.
Thanks for any information!
Old Nov 8, 2006 | 08:08 PM
Elton's Avatar
welcome to yotatech.... sure it can sounds like a big boat .... if you do some small mods to the 22re it well help
Old Nov 8, 2006 | 08:13 PM
4runnermt's Avatar
Here's a couple shots of my '94 22re hauling a 3,000 lb boat. I wouldn't recommend highway towing though.Name:  IMG_1824.jpg
Size:  29.8 KBName:  IMG_1836.jpg
Old Nov 8, 2006 | 08:40 PM
mercury89's Avatar
Thanks for the quick replies, unfortunately I would have to tow on highways with posted speeds of 65MPH.
If I get this truck then I will probably have to keep my Jeep Cherokee for towing the boat.
By the way, the 4runner has a broken timing chain at the moment (broke yesterday) do you guys think the truck would be worth fixing if I can get it for under 500 bucks?
It has 280,000 miles on it and the engine was rebuilt at 100k.
Any advice?
Old Nov 8, 2006 | 09:26 PM
toy283's Avatar
A broken timing chain can lead to expensive problems. If you can, find out the circumstances of the break. If it broke during startup (like mine did), there is a good chance it's OK. If it was running when it broke, there is a good possiblity of bent valves and damaged pistons. Replacing a timing chain isn't expensive if you do the work yourself, but if you start getting into heads and pistons, the cost goes up quickly.
Old Nov 8, 2006 | 09:41 PM
Elton's Avatar
ditto my timing chain snapped on my 22re wasint pretty
Old Nov 8, 2006 | 11:05 PM
bob200587's Avatar
I think there's 500 bucks worth of parts in that 85 even if the engine is bad.
Old Nov 9, 2006 | 02:36 AM
WVpizzaguy's Avatar
ditch the heep... going to a beat up '85 4 runner that you have to push is an improvement.
Old Nov 9, 2006 | 06:25 AM
mercury89's Avatar
Thanks for the info, I guess I will see what the circumstances of the break were.
Old Nov 9, 2006 | 07:26 AM
04 Rocko Taco's Avatar
keep the heep for towing, give me the oppurtunity to buy the 85 for a couple hundred bucks....
Old Nov 9, 2006 | 08:20 PM
4runnerx3's Avatar
I pull my 2000 lb Correct Craft Mustang with my 4runner with no problems.
sandyota
Feb 4, 2021 11:16 AM
deepmarsh
Aug 6, 2015 03:44 AM
adammtb
Jul 27, 2015 11:57 AM
bryan34w
Jul 6, 2015 05:53 PM
