04 Taco RR Diff and ABS Light on for no reason - Need Help Please
Old Oct 18, 2006 | 06:43 AM
FCRunner's Avatar
Question 04 Taco RR Diff and ABS Light on for no reason - Need Help Please
My RR Diff and ABS Lights on Dash came on for no reason after driving my 04 Taco about 500 miles and towing 500# trailer. Next morning, RR Diff light was fluctuating from dim to bright, then, after about 5 minutes of warm up, RR Diff light went solid bright and ABS light came on again too. Does not seem to be related to vibration.
Thanks in advance for help! Here's the specs:
'04 Taco 3.4L SR5 TRD
56K miles
2.5" lift / 33" Tires
Recently added wiring harness for trailer lights
Was raining a bit during trip
Old Oct 18, 2006 | 06:46 AM
Elton's Avatar
if you have a factory locker then it sounds like its on wich shuts off the abs
Old Oct 18, 2006 | 06:50 AM
BajaRunner's Avatar
Im sure you tried to switch off the locker, but, its normal for the ABS to turn off when the locker is engaged.
Honestly though that sounds like an eletrical problem if the locker is truely not engaged. You sure you cut the right wires
Old Oct 18, 2006 | 07:00 AM
FCRunner's Avatar
The light came on during driving in 2 wheel drive - all highway for the previous 500 miles or so... I stopped, put in 4Low, engaged OEM locker, RR Diff light blinked, turned RR Diff OFF, went back to 2Hi, ABS and RR Diff remained solid on.
Thanks for help...
Old Oct 18, 2006 | 07:02 AM
FCRunner's Avatar
No, locker was not engaged (at least I did not turn it on...). I purchases a trailer wiring harness esp. for 04 taco - had connectors that ran in-line with existing taillight connectors (no wires cut...) All the trailer lights work fine still...
Thanks for help...
Old Oct 18, 2006 | 08:18 AM
Godzilla's Avatar
If you engaged the locker (light blinking) but it did not lock and you shut it off, then maybe something i fishy with that. Lock it, get a solid light, then unlock it.
Old Oct 18, 2006 | 08:20 AM
Godzilla's Avatar
Actually this really sounds like the most probable problem.
Old Oct 18, 2006 | 09:11 AM
Smiling_Jim's Avatar
It aint the locker...
You have bad speed sensor. Not sure about the Taco electricals, but my 99 Dodge had the differential speed sensor fail. It was $40 and 1/2 hour to replace.
The Dodge also had a sensor on the trans. The diagnostic machines could not find the problem, so it took me a while to find and fix it.
Also, don't cut the wires. The OBC needs sensor signals to keep things running right.
Old Oct 18, 2006 | 04:56 PM
FCRunner's Avatar
Thanks Godzilla! I 4 low-ed, locked er up, ran a 1/4 mile or so on a snowY dirt road, unlocked and both FF diff and ABS lights went out! Ran 30 miles or so in town in 2hi, 2 miles up dirt road in 4hi, no lights. Looks good so far
For the crowd out there: Does this appear to be a ECU issue with 500 miles of towing on 33" tires with no gear change, or, does this look like a sensor or other part going bad???
Thanks again Godzilla - Go YotaTech
jerusry
Oct 19, 2015 05:28 PM
jaretstuff
Aug 4, 2015 02:08 PM
nonstop
Jul 24, 2015 06:29 PM
Steven.m.paulk
Jul 24, 2015 01:44 PM
scottyg486
Jul 19, 2015 05:34 PM
