3.4 5vz-fe 5vzfe engine harness intake injectors parts for sale TN
Old Aug 13, 2006 | 03:19 PM
kwikrnu's Avatar
I recently purchased a '95 tacoma with the 3.4. It was missing and leaking at the rear seal and maybe the oil pan. I did a compression test and the #5 cylinder had about 140 psi compared to 180 or so on the rest. It ran and made good power and I do not think it had any headgasket leaks because there was no oil in the coolant and no coolant in the oil.
So, I replaced the engine a week or so ago and now have an engine I do not think I need for parts sitting in my garage taking up space. I think the engine is the original engine that came on the truck and if the odometer is correct it has approximately 215K miles. I ran the truck a few hundred miles before the swap and never had any trouble codes and I have a code reader. I am willing to part it out. Some of the stuff is damaged such as tps, timing belt cover and power steering pump. The wire harness is from the new engine so I do not know what it actually fits but I have pics. The injectors should be 240cc they are blue. I have a/c bracket. Electrical harness for starter. Heads, valve covers, intake, fuel rails, oil pan, flexplate, alternator, lots of sensors like crank and camshaft position sensor cps etc. I'm going to hold off on selling the coil packs and wires for now but may reconsider.
Make an offer on a part you need and I'll let you know.
I'll sell whole thing for $400 but absolutely no shipping because oil is coming from rear seal.
Located 5 miles from Nashville Tennessee.
kwikrnu@bellsouth.net
Old Aug 13, 2006 | 04:03 PM
kwikrnu's Avatar
I really don't know what the harness/engine came from or what year or how many miles. I do think it was from an auto transmission because there are several connectors which go to the tranny.
Only one of the connectors is kinda broke/melted/scratched. It is the connector for the #1 cylinder coil. The plate where the harness attaches to the firewal is bent as well. I removed the little square electronics thing shown in pic that usually rests near maf because it was melted.
I'll take $125 for the harness and $15 to ship.
I will sell with engine all for $400 but I won't ship the engine you'd have to come get it.
Old Aug 14, 2006 | 11:26 AM
kwikrnu's Avatar
I'll sell the 215k mile coil packs and wires for $60 shipped. They worked great in the old engine and in this new one until I stuck the lower mileage ones in yesterday evening.
Old Aug 15, 2006 | 04:16 AM
halfshaft5@aol.com's Avatar
Interested, I am in East Tennessee and can pick up, send pics of the motor to halfshaft5@aol.com also what about a computer?
Old Aug 15, 2006 | 06:44 AM
kwikrnu's Avatar
There is no computer. The coil packs do not go with the engine and I'll post some pics in a few hours but it looks like any other used engine. except one of the bolt holes is broke on the upper plastic timing belt cover and the power steering unit is broke. I have 3 worn out belts as well. It is missing a few of the bolts for the intake and the 4 nuts for the fan pullies.
Old Aug 15, 2006 | 07:17 AM
kwikrnu's Avatar
The engine should run right out of the box but like I said the compression was low on #5 and it really needs a rear oil seal because it did leak on the engine and since the engine has been out it has leaked on the floor a bit. It will also need some intake gaskets because I used the intake from the old engine on the new engine.
Old Aug 16, 2006 | 07:35 AM
kwikrnu's Avatar
Here is a question someone ased me about the engine and my reply.
Originally Posted by someone
hey man what needs to be done to get the 3.4 running
You'll need new gasets for the intake. New rear main seal. Maybe rings or head gasket or pison or head or valves for #5 cylinder. Maybe new oil pan gasket. You will need an ecu a power source a starter belts throttle cables mass air meter and itake vacuum hoses water hoses radiator and lots of stuff.
This engine is not from a pristine 10000 mile truck. It is from a 215k mile truck and had low compression on a cylinder and a leak in the rear main seal I think. I would not buy this engine to install in a truck to use as is. If you consider doing a build up this would be a good engine.
Old Aug 29, 2006 | 08:28 PM
hman1991's Avatar
how much for the heads shipped to 49408? or just the right head shipped.
Old Sep 15, 2006 | 10:11 AM
kwikrnu's Avatar
$225 shipped for the heads with teh cams and valve covers. But I would suggest they be taen to a shop to be checed out and cleaned etc.
Old Sep 18, 2006 | 03:24 PM
Bigblock's Avatar
I'll buy your wiring harness.PM me.
Old Sep 27, 2006 | 02:44 PM
Bigblock's Avatar
Heck I'll buy the complete engine and come get it.Has it sold yet?
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
greenbuggy
Jun 28, 2015 10:40 AM
Edionne13
Jun 21, 2015 11:37 PM
TheManOutside
Jun 18, 2015 03:32 PM
HBoss
7
May 26, 2005 04:48 PM
