22RE cylinder compression/ engine removal and swap questions
Old Jul 23, 2006 | 04:19 PM
the4x4runner's Avatar
I have a 86 4runner 22RE 5speed 4X4 IFS that has poor compression in #1 cylinder.
The compression is only bad in the cyclinder and improves when oil is added meaning its the rings or the cylinder. The engine leaks oil from the pan and the dipstick, maybe other places. The dealership wants an outragous amount just to open it up and look to see whats wrong. I think its bad when he starts quoting me prices to just replace the block. ($3500-$5400).
I only paid 1k for it and dont want to , nor can pour alot of money into it right now. It may be as simple as changing the rings, but i dont have the money to have the rings replaced or cylinders machined and dont want to get into opening up the engine. I have found a complete engine w/ 100K that runs well and was thinking of just swaping engines. i think i can handle that (I have some friends and can rent a hoist).
I've done some searching to find if i need to remove the tranny to take the engine out with no luck.
Can i unbolt the tranny and remove the engine ( after everthing else is unplugged/unbolted), or do they have to come out together.
This is unless there is some miracle stuff you can add to improve the seal of the piston rings. i think that is why my oil leaks, because the combustion of the engine is leaking into the oil pan and causeing excessive pressures.
Thanks for any input
Old Jul 23, 2006 | 05:07 PM
ovrrdrive's Avatar
Well, how much are you paying for the engine with 100k on it?
If its under $400 I would be tempted to do it but anymore than that and you are asking for trouble.
And keep in mind that this engine is only a band-aid. It's highly possible that you'll need to replace it again in a few years...
Old Jul 23, 2006 | 06:28 PM
the engine selling for 400 or 450. ive only put 60K on my other truck in the last 5 years, so i think itll last me.
Old Jul 24, 2006 | 07:28 AM
Adams90Toyota's Avatar
I have a 90 pickup with a 22re and i had to replace about the whole motor, but i took the tranny off and didnt pull it with the motor.
Old Jul 24, 2006 | 07:39 AM
4Hummer's Avatar
I left the tranny in, Unbolt from the flywheel. 4 hours and I got this
Old Jul 24, 2006 | 08:00 AM
ironroad9c1's Avatar
i've done it both ways ,and to tell the truth i'd rather unbolt the tranny that pull the whole thing ,gets kinda tight around the front axle and sway bar area and t case .
Old Jul 25, 2006 | 02:48 PM
It is kind of hard to get to a few of the bolts tho.
GreenLion
Jun 7, 2021 10:49 AM
TheManOutside
Jun 18, 2015 03:32 PM
bobbybouche
Jun 18, 2015 10:22 AM
Old Red 94
Jun 16, 2015 08:32 PM
