Help with in-process 3vze vlv cover gasket job
Based on some discussions from this board I traced an oil leak to both of my valve covers... I used the thread here:
https://www.yotatech.com/forums/show...e+cover+gasket
which rocked, by the way. Right now I can almost lift the plenum up high enough to start on the valve covers. My current questions are:
I'm betting that both of my cam rear seals are leaking as well so I also am replacing those tomorrow. As I understand it, as long as I don't rotate the cam while I am slipping those in behind it, I won't mess up the timing.
I'm posting some pictures of where I am currently at. Do I need to remove anything else? I stopped tonight when the one hose in front of the throttle refused to loosen. I sprayed it down good with PB-Blast and figured I'd try again in the morning. The plenum lifts up pretty good but either something else is holding it down or it is really heavy.
Other things I've seen... My plenum is really nasty from all the bad gas I'm using. I'm planning on cleaning that out as good as I can later. I'm also planning on changing the oil (I changed it last week b/c it was due) in the next week or so.
There is an allen bolt on the back of the intake plenum that you need to remove. Most people have to hunt for it. (In other circles, such as my old Mx6.com and probetalk.com forums we called that a "B*tch Bolt") Its a pain, but its back there, good luck. Search on here, I know I've seen some pictures on here of it during some engine rebuilds, should help you out.
Ok, good news is that left side (from driver perspective) is done, including replacing the rear cam seal. Thanks for the answers to my previous questions.
And, I got the plenum fully disconnected and on its right side giving me full access to the right valve cover.
New problem: The cover is loose but I think the plastic t-belt guard is holding it on? Am I mistaken? The cover wiggles but it won't let go. I removed all 10 bolts and the rear is bumped up against some stuff that I don't think I can remove.
And the harness is so far not in my way. I gave up disconnecting it when I saw two electrical connections down at the oil filter.
Did I say there were 10 bolts? Yeah, I think 10 was the total for the LH side. Looks like the RH side had 11 bolts....
The cover is off, albeit by struggling with all the freakin' wires. It's gonna be one huge pain in the rear to get that sucker back on with the mess I've got right now.
My drill wasn't doing too well on the old pcv valve so I gave up on the pcv mod until the next time. Maybe my carbon drill bits are not strong enough.
New problem. Truck cranked up fine and ran fine (after I realized my gas tank cap was loose and tightened it down).
However, when I let off the gas I get a simultaneous "A/T high temp" light and a CEL which then go away immediately. The RPM's also seem to jump down and then back up.
I also had the following leftover parts...
ChickenLover, thanks for all the help! My experience working on cars is limited...
Ok, new day so I did some more looking around. I think I broke my TVV in the back of the plenum...
I'm gonna try the TVV mod from this string and try to do it without removing the plenum. Is this gonna work?
https://www.yotatech.com/forums/show...&highlight=tvv
picture of snapped off hose:
fuzzy picture of the broken TVV:
the1998sr5
15
Jul 14, 2020 08:35 PM
Sep 4, 2015 09:27 AM
scottyg486
Jul 19, 2015 05:34 PM
