will sway bar help with wheel stuffing?
Old 06-27-2006, 03:37 PM
TX-BLKRUNNER's Avatar
i am currently running with out the rear sway bar, and since i have done the spacer kit and larger tires the drivers side, rubs the gas tank nozzle cover, will the sway bar prevent the tires from stuffing completly?
Old 06-27-2006, 04:14 PM
KyleT's Avatar
i took my rear off and it drives soo much better on road. the off road performance isnt that bad either but it is limited. i dont rub on the back, but i have the daystar bumstops that Steve Schaefer sends with his lift kit.
Old 06-27-2006, 04:23 PM
snap-on's Avatar
is that an indication that you need a panard bar drop to go with your lift? (if im thinking about that right?)
Old 06-27-2006, 05:30 PM
KyleT's Avatar
hmm, yeah i would assume that the panhard bar would help with that,
here is a pic of it with the swaybar and without.
with:
without:
i did not notice any rubbing so if it did it was barely any. not close to the gas tube or anything like that. i dont have a pic of it flexing hte drivers side without the swaybar. but it flexes pretty much the same.
I have 265/70r17's which is like a 32.2" or something like that
Old 06-27-2006, 05:33 PM
AH64ID's Avatar
When I pulled the sawy bar off my 95 I didnt noticed a whole lot of change, so I left it off. Its a very small sway bar, I'd leave it off, it will be slighty better offroad...
Old 06-28-2006, 11:58 AM
well i put the sway bar back on, and it was just enough to keep the tire off of the gas tube. thanks for the input
nvdesertrunner
05-11-2020 08:18 PM
4.34runner88
08-11-2018 10:44 AM
andrewtexas123
07-06-2016 01:49 AM
coffey50
07-28-2015 10:55 AM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: will sway bar help with wheel stuffing?
