Any math gurus out there?
Ok well I am trying to fab somthing, and it consists of a square with a piece of flat stock on each side sticking off of it at a 45 degree angle. NOW, this creates a gap at each corner. The pieces of flat stock are all 1/8" thick, and 2.5" tall. To fill this gap, I want to cut some triangles to fill it. The triangles will have the two sides that butt against the flat stock being 2.5", but my question is what will the top be? I know there is some formula to figure this out, but I have no idea what it is.
Here is a diagram of what I am describing:
Thats it for the high school word problem...
on what axis are those 45 degree angle based on? is the corner going to be a true 90 degree (as 2 45s would make it)? or is this a 45 degree angle, then a piece, then another 45 degree angle, then another peice? if its a 90 degree angle between the 2 peices, then the measurement will be around 3.5 inches. if its 45 let me know and i can crunch some more numbers
I conquer if B is a 90 degree angle then C is a 90 degree angle, there for the pathagram therom would work, which for those who forgot is what shiftless put down and OLY worked out and the answer would be 3.5355
that was fun anymore
The picture itself is very misleading. Assuming that he wants each piece at a 45° angle relative to the center, then yes, the 3.53" is correct. However... that picture isn't even close to that, and if that is what he wants it as, then the angles need to be measured, or better yet, get a ruler. His discription seems to verify that indeed it should be a right triangle, but you never know.
I kinda see it diffrently
i interpert his 45deg to mean that both peices of steel are tilted up and not laying flat as many have assumed.
if they were laying flat on a table yes it would be sqrt2*a side (in this case 2.5) or as mentioned 3.5 and change.
but in fact its less than that becuase the steel is sitting at a 45 deg angle to the flat table. (really the shown dimention would be 135deg)
for instance As the green angle aproches 90deg the distance in blue would aproch 0 (as in the sides of a box)
so in that case i say it is in fact much less than 3.5" (and you can kinda see its at least as "short" as the red 2.5" line if not shorter)
if in fact im right it becomes a non trivial gemoetry problem to calculate, when in the real world its much easyer to just put a tape across the opening
Snap-on is right, what I mean is the pieces of flat stock are sitting at a 45 degree angle to the flat surface (which yes is actually 135 degrees). It is going to create a funnel-like object. And yes the corner will be a 90 degree angle.
right so useing the orthographic projection
it should boil down to something like sqrt2(hyp*sin theta) (were theta is defined as the angle of the sides off the vertical projection)
or in our case sqrt2(2.5*sin 45) = (in this special case) 2.5" (only because the 1/(sin 45)=sqrt 2, you got to love math, oh is my nerd showing?)
(which is why i said it looks almost the same distance as the red line)
someone veryify please
(note im useing the sqrt2 shortcut for a right triangle with both sides equal)
√2.5+2.5 = 3.54.
If where it says "45 degree angle" is 45° from horizontal, the angle where the two pieces of metal come together is 90°. The two shortest sides of any right triangle equal the square of its longest side. So we have 2.5+2.5=12.5, which the square root is approximately 3.54.
I tried to keep the colors consistent with the original picture. Looking at the side view (Staring straight at one piece of metal), we can say that both side equal "a". We can also say that the length of the dashed blue line is equal to the sloid blue line form the original diagram. If we look from above, we can also see that both two pieces of length "a" form a right triangle with a hypotenuse equal to that of the lenght "?". By looking at similar triangles, the hypotenuse of a right-angle triangle with sides "a" must equal 2.5".
I'm pretty sure I'm right, but if someone can prove me wrong I ask that you do.
EDIT: What I forgot to say was that that the length that we're looking for is 2.5". thanks to snap-on for doing all the work.
Hold the pieces where you want them, enlist other hands as needed.
Take a piece of cardboard/anything, and hold it in the area of the desired piece.
Trace the sides of the other pieces onto the board.
Cut piece slightly outside of lines.
Put in place.
Adjust as needed, no math involved.
Put in place.
