What is timming on 22r EFI ?
Old Apr 11, 2006 | 12:11 PM
toy4crawlin's Avatar
I just installed Dual timming chain Sat -Sun on my 85 22r EFI
I'm at 8* Cold
Got it running and started Driving home, and 4 blocks later it Died when slowing down for traffic at 20 mph.
waited 10 minutes and it started again, Drove on Freeway 65mph, runs great, Smooth, 15 minutes on highway.
Then near home and it died when slowing down t o stop at light.
Towed it home, Engine starts, runs smooth at 1000RPM idle, then warms up and dies.
I'm at 8* with Te jumpered. Cold
The Haynes manuel does not say, it says put on 0 @ TDC
Roger 4crawler.com says 5*
Some people say 13* cold
Some people say 8*
read somewhere put at 16*
Engine sometimes runs well and can drive , when slow down it dies.
Engine sometimes starts , idle then dies
Came home from work Monday , engine Starts then dies in 2 seconds
try again push gas and it just dies
The Timming Has to be OFF ????!!!!???
LC engineering says I have Fuel Pressure problem
I have Fuel flowing and NEw Fuel Filter !
How do you test Fuel Regulator ?
Old Apr 11, 2006 | 12:52 PM
Nix_Toy's Avatar
it's 5*BTDC, Warm
Old Apr 11, 2006 | 10:43 PM
kyle_22r's Avatar
with the jumper in place, and engine warm, you want to set your timing to 5*BTDC as a starting point. with the jumper removed, it should read about 12*BTDC.
Old Apr 17, 2006 | 03:03 PM
Originally Posted by Nix_Toy
it's 5*BTDC, Warm
thanks But if you just put engine back together the Engine is cold .
Does not make sense to run engine on bad timing until engine has warmed up
Old Apr 17, 2006 | 03:27 PM
You get a False reading if you remove the Jumper
thanks all but now the Engine no longer runs
Just starts and Dies, Just starts and Dies, Just starts and Dies, Just starts and Dies, Just starts and Dies, Just starts and Dies,
NEw Vacuum lines, I drove on them for a Week before timing Chain install
New Plug Wires, drove on them for a few days before new chain 9tear down)
I installed new timing Chain
- Engine would not start, sprayed carb spray into Intake, Engine stayed running (while spraying).
2- Disconnected Starter motor, turned Ign Key on/off, to Pressure up the Fuel line
3- reconnect Starter, Engine starts and Runs,
4- Set Timing, 8*, Engine run great
5- Drove 4 blocks , stop for 3 stop Signs and Signal light
6- Slow down for signal light Engine Died
7- Won't start
8- Waited 8+ MINUTES, Engine Starts up
9- Drive on Hwy 65MPH for 15+ minutes, very smooth and quite
10- Slow down for signal lights
11- Slow down to 4th Stop light, Engine DIES
12- Wait 10 minutes , engine starts up again, Drive 25 mph 1 Block to home
Engine Dies
13- Reset timing with Jumper to 8* Cold
14- Next day, Engine no start
15- No Engine Codes
16- Swap out ECU's
Checked Fuel pump
Checked Fuel Filter
Checked Intake air leak
Checked Spark
All Engine Grounds in place
17- By pass the VSV Valve
EGR Is Blocked off, This way for 1 year, 1k miles
17- Bypass stock coil, I'm using a Jacobs Coil, but still wired to Toyota Igniter
Truck No Run 8 days !!!!!!!
PLEASE HELP
Valve job last year, Could they all of a sudden be to Tight ?
Is this igniter Related ?
Is it a bad Fuel Dampner?
Bad TPS
Bad AFM
Old Apr 17, 2006 | 03:56 PM
AH64ID's Avatar
My jacobs setup would do that, I always carried the stock wire to bypass the jacobs. I went thru 4 jacobs units and gave up (all were warrenty)....
Might be too much timing...but should still run...
recheck all you connections, might be something simple...
Old Apr 18, 2006 | 09:31 AM
IT"S ALL FIXED.
RUNS GREAT !!
I was poken and pulling on all wires and for some reason ( I did not do)
The resistor Yellow Plug on passenger fender was NOT SNAPPED IN
I would post picture , but the Kb and size is to small
buckz6319
Aug 5, 2017 03:50 AM
Iceman4193
Oct 16, 2015 10:50 AM
mreagen
Oct 5, 2015 04:27 PM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
Toys4parts
Sep 26, 2015 01:56 PM
