93 3.0 v6 needs a tune-up. Can anyone help?
Hi there,
I'm located in San Francisco and my '93 v6 pickup needs to have the timing belt, water pump, and pulleys replaced. I would like to do the job myself but I'm scared to screw anything up...
Any volunteers? I'll provide the pizza & beer
-Eugene
-Eugene
Originally Posted by tc
I was a little nervous about doing mine too. If you're reasonably mechanically inclined, you can do it. There are several writeups on here how to do it.
try this:
http://personal.utulsa.edu/~nathan-b...67timingbe.pdf
i did mine over the christmas holidays, go slow and read things as often as you need to make sure you have it right. its a time consuming job but doable by yourself. im pretty sure there are a few members nearby that may be willing to help out.
good luck and keep us posted.
lee
lee
Originally Posted by leebee
try this:
lee
lee
The PS pump is the biggest PITA in everything you're about to do. I highly recommend you remove the PS Pump and the radiator, too. I didn't and it made things a lot more difficult.
Also, the step where they say disconnect PS pump from engine, do I actually have to remove all of the connections to the pump, or should I just keep it connected but move it aside from its mounting location?
I was never able to remove my pulley; I ended up bending the crap out of it with a 6-foot steel bar and it STILL didn't come loose. Good thing I was replacing it anyway!
matthewdmueller
May 19, 2008 12:11 PM
matthewdmueller
May 19, 2008 12:09 PM
