Replaced timing belt,marks were perfect,but not now
Installed new belt,tensioner,seals,water pump.Had crank and cams lined up on the marks but now they are off a little and getting a tapping noise.Why are the cam marks off a little? Doesn't the crank mark set on the 0 mark at TDC??? NEED HELP THANKS
Jim, just a suggestion, but I noticed you have a continuation of the same topic in 4 threads and it is usually easier to just have one thread and continue with asking questions/diagnosis in that one since it gets confusing to have the same topic for your truck discussed in multiple threads. That way if someone else comes along and wants to learn from what you went through there is a logical progression of diagnosis and repair hopefully leading to a fix at the end.
https://www.yotatech.com/forums/showthread.php?t=78968
https://www.yotatech.com/forums/f2/timing-belt-broke-tapping-noise-now-1998-tacoma-v6-78947/
https://www.yotatech.com/forums/f2/tapping-noise-1998-tacoma-v6-78911/
https://www.yotatech.com/forums/f2/timing-belt-check-change-1998-tacoma-v6-78806/
You might just copy your question into your first thread and delete the others. No, need to worry, I guarantee you'll get answered on YT (you can always bump your thread......by posting..... to the top if you want to).
Maybe a moderator can help you combine this all into one thread.
I found this in a search too:
https://www.yotatech.com/forums/f2/timing-belt-replacement-3-4l-40560/
voiddweller
19
May 2, 2016 09:10 PM
FS[MidWest]: 1995 4Runner 5vz 4x4
vasinvictor
Jan 20, 2016 12:39 PM
infinityisfive
Jun 16, 2015 06:51 PM
