50 shot of Nitrous oxide
what better way to spend my day off this friday than to try to blow up the 3.0 with 75shot of nitrous oxide..ill gerry-rig something up where ill hook up a fogger nozzle to the intake tract. hopefully i can get a few runs in before something blows up.ill pump some 91 and pull back the timing to make things a little more comfortable inside the combustion chamber..Should be fun
p.s before i get heat from all of you for doing this i tried selling it but no takers, might as well have fun blowing it up.
For the car v6's the long suggested is a maximum of a 75 wet shot.
Not because the engine's won't handle 150-200 depending, but becuase the fuel systems can not sustain fuel, even when using a wet fogger nozzle. Extra fuel must be added.
So, there ya go, I'm telling you like sean & I tell all the car guys.
75wet shot = the max you want to run on current fuel pump, ECU (no management), stock FPR, and stock injectors.
If you want more than that, you'll need to change the pump & devise a way to get more fuel than a wet nozzle will supply.
You've got an airflow meter... Dial it a few clicks rich & suffer running like Blah all the time.
Originally Posted by dsm59
...ill gerry-rig something up
... might as well have fun blowing it up.
make sure you have video
spiewaker
Dec 16, 2015 01:10 PM
