How much oil do you go through?
Old Jan 13, 2006 | 09:30 AM
Caffeine's Avatar
So between oil changes, how much oil does it take to keep the dip-stick at full on your 3.0?
Right now, my '94 pickup is chugging it back at a rate of 1.5L per oil change. It's got about 215,000Km on it. Is this normal?
Old Jan 13, 2006 | 09:36 AM
eric-the-red's Avatar
Sounds about the same as the 93 I had, 1.5 - 2L in between changes. Mine had 220,000km on it.
Now that I'm driving an 01 I don't use any
Old Jan 13, 2006 | 09:46 AM
Corey's Avatar
Co-Founder/Administrator
Not a drop, and that is twice now going around 8K or better with my Amsoil.
Even with my engine running on only 5 pistons, it still does not use a drop of oil.
Old Jan 13, 2006 | 10:06 AM
bflooks's Avatar
98 4cyl with 150k....not a single drop.
Old Jan 13, 2006 | 10:28 AM
celica's Avatar
I go through about .5 of a litre between oil changes around every 5000km. If I am doing a lot of heavy towing I will use about 1 litre. My motor has 386,000 kms on it
the camry is about .5 litre with the V6 and 378,000 kms on it
Old Jan 13, 2006 | 10:53 AM
Silver_Truck's Avatar
.5-.75 quarts, doesn't help that I have a leaking oil pan gasket
Old Jan 13, 2006 | 11:08 AM
Slowrunner's Avatar
I don,t bother topping up , only go through .5 a litre/5000km or so, and thats with a leaky distributor. I use 5W30 toyota oil & filters . Its has 80,000kms (freeway miles) on a 2 year old dealer HG recall rebuild. (222,000kms on vehicle)
Old Jan 13, 2006 | 11:27 AM
4Mogger's Avatar
X2
Have 180K on my original 3.0 and run Amsoil series 2000 0W30 syn. I have run Amsoil since it was new (switched at 30K to allow the motor to break in) and change it once a year and works out to about 10K miles. Also have the dual remote bypass filter system.
Old Jan 13, 2006 | 12:16 PM
Glenn's Avatar
All engines will burn some oil because it gets in places where it won't return to the oil pan, such as the valve guides and above the piston rings.
Old Jan 13, 2006 | 12:26 PM
4mydogs's Avatar
My 3.0 needs a quart between changes. It has 145K on the clock, and doesn't leak a drop, so it's getting burned somehow, most likely like Glenn said above.
Old Jan 13, 2006 | 12:51 PM
Paul H.'s Avatar
Mine will usually get to between full and refill after about 3k miles.
Old Jan 13, 2006 | 01:50 PM
Toyofast's Avatar
Never need to add any oil.... just under 309K miles now on my 3.0 V06 was done 120K ago but no major parts were replaced.
Old Jan 13, 2006 | 01:54 PM
4x4Lamm's Avatar
Bout' a quart every 3000-5000 miles.
Lamm
Old Jan 13, 2006 | 02:32 PM
surf4runner's Avatar
no 3.0 but at least a quart every three tankfulls on the 22re no leaks it just burns, not a drop on the 3.4
Old Aug 8, 2006 | 06:48 PM
USAtruck6's Avatar
this is my new dilemma....I go through 6 - 8 quarts every 3km.
I need a major engine rebuild
Old Aug 8, 2006 | 06:57 PM
RustBucket's Avatar
Me too, about a quart per fillup.
"Fill up the oil, top off the gas!"
(that's what you get when you put a brand new head on top of an tired old block!!)
Old Aug 8, 2006 | 07:22 PM
^VooDoo^'s Avatar
I might put a qt in every 1k, I also change mine every 2k, I abuse the engine, I dont let it abuse itself.
Old Aug 8, 2006 | 10:09 PM
USAtruck6's Avatar
I didn't think of it like that, but your right.
Glad to know I'm not the only one!!!!!!
I'm hoping next year to have it rebuilt.
Old Aug 8, 2006 | 10:21 PM
ChickenLover's Avatar
1 quart per 3k miles.
Old Aug 8, 2006 | 10:51 PM
jct61765's Avatar
none.
