General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Looking for a good momentary switch
Old Jan 6, 2006 | 06:10 PM
4x4Lamm's Avatar
I am having a hard time finding a decent momentary switch at stores and on-line.
I need a switch that is momentary, can handle 10-15 aps and installs with a drilled hole preferably.
This is the best so far:
http://www.streamlinerods.com/produc...d=663&catid=94
And does anyone know if this can handle 10 amps?
http://www.sdpc2000.com/catalog/3241...58/default.asp
Any other ideas or links would be nice.
Thanks!
Lamm
Old Jan 6, 2006 | 10:29 PM
RED 85's Avatar
I am looking for some also. I went radio shack and didn't have what i was looking for and the guy there told me to try Fistell's. They are here in Denver and online. I haven't had the chance yet to look them up but it is worth a try.
What are you going to use it for?
B
just tried the website and it is not working.
Old Jan 7, 2006 | 12:07 AM
jsnby's Avatar
try jameco and digi-key. Jameco is easier to search.
Old Jan 7, 2006 | 05:31 AM
EnolaGaia's Avatar
Originally Posted by 4x4Lamm
...And does anyone know if this can handle 10 amps?
The one you cited is a Holley / NOS momentary switch, for which not even Holley's own webpage gives specs:
Pushbutton Switch
Part #: 15610NOS
http://www.holley.com/products.asp?product=15610NOS
However, Holley / NOS offer a 30 Amp relay:
30 Amp Relay Assembly
Part #: 15618NOS
http://www.holley.com/products.asp?product=15618NOS
... you could (maybe should?) probably use to ensure robust operation...
Old Jan 7, 2006 | 05:43 AM
EnolaGaia's Avatar
If the larger push-button switch of the sort you cited (Streamline Hot Rod Parts) is acceptable:
The most common unit on the market is the Cole Hersee M626BP momentary starter button, rated at 35 amps.
Hint: If such heavy-duty starter-type switches are what you're after - look in the marine marketplace. They're much more commonly used on boats, and suppliers offer water- / weatherproof variants.
Old Jan 7, 2006 | 11:32 AM
tc's Avatar
tc
Go to Boater's World or West Marine. Boats do not use relays - their switches are rated at least at 20A.
Old Jan 7, 2006 | 02:29 PM
4x4Lamm's Avatar
They will be used for an emergency vehicle sire. They only need to carry 10 amps for very short periods of time (less than 5 seconds) I don't want to have any more relays. I have to many already.
Does anyone know how hard those starter switches need to be pressed? I want something that is easy to tap with one finger and can be mounted of somewhat thin plastic.
Thanks!
Lamm
icentropy
Jul 14, 2015 10:23 AM
Johntom240
7
Jul 13, 2015 12:18 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
crashburnoveride
Jul 10, 2015 06:39 AM
colinmil
Jul 6, 2015 04:03 PM
