Intermittent starting on 3rd gen
My wife's 99 SR5 has 99k miles. Is up to date on ALL service work. It has not been wheeled in a long time--no mud or anything.
It currently has a 3 year old Interstate battery. However, the last week when you go to start it--nothing. THe lights work, but nothing. Not turning over, no click of the starter. Do that about 3-4 times and it starts. OR other times it will not start right up, like the battery is not fully charged.
I have not had the battery tested.
I was wondering if anyone else has ever experienced the same issue
Originally Posted by Travs97
could be a dead cell in the battery
Try the following test to isolate the source of the problem:
- http://www.4crawler.com/4x4/CheapTri...shtml#EasyTest
Originally Posted by MTL_4runner
It sounds like starter contacts or battery to me.
Does it make any difference if you jump the vehicle when this happens?
Would starter contacts cause intermittent issues??
Originally Posted by FilthyRich
there is no need to jump it b/c within 3-4 tries it starts---at least that is what it has done the last week. The battery is not sealed and might need water.
i had similar intermitent starting issues. replaced the starter and works great everytime now. i replaced the contacts in the old starter and have it as a spare. we put it on a friends truck a few weeks ago, and works awesome. i would put money on your problem being solved by doing the starter
filthyrich
I had this same thing going on with my 98 just about a month ago. Right at 90,000 miles on my Runner It just started out of the blue and progressivly got worse in the next week. I did the same thing that you are doing, I would turn the key on and off a few times and it seemesd to be OK and start up.
I took it to my very trusted independent toyota mech and he told me that the contacts were going bad on my starter. It seems that this is common and that it's not that big of a deal to fix, not by me mind you. He replaced them and have not had any trouble since. Cost me about a $ 100.00 to get it fixed, but it was going into the shop for other things anyway.
Hope this helps Doug
Originally Posted by ebelen1
Not on my runner but on my old Accord, I had something similar. When it takes a few times to start the car, it most likely is the battery. As you know, the battery starts the car but the alternator keeps it going and charges the battery at the same time. When batteries stop taking the charge, your type of situation can occur. Why not go over to Sears or similar place and have them test the battery? It's free and w/ a baby on the way, it would be horrible for you or your pregnant wife to get stuck.
I had the same thing in the first 99 i had. Some days it was perfect. Others, the lights, etc would work and there would just be NOTHING from the starter. I'd try it several times, and then you could hear a faint "click" and then it would turn over like nothing was wrong. The battery was strong, terminals were clean, and I couldn't find anything wrong w/ any of the fuses and relays. It stumped me until I thought of checking the starter. It had LOOSE starter contacts - the nuts on the contacts were simply loose. I got under it, cleaned the contacts and then tightened them down good and it never acted up again.
If that's not it, then make sure the main fuses aren't corroded on the prongs and that the battery terminals are clean.
