Anyone's tachometer have ADD?
Old Oct 26, 2005 | 11:19 AM
4x4Lamm's Avatar
Question Anyone's tachometer have ADD?
I swear my 4runners tach has ADD.
It works fine under throttle, but when at idle it sometimes randomly drops to 0 RPM or just bounces around like crazy between 0 and 1000 RPM then settles back to normal for no reason and at totally random times. Once you start to accelerate it works fine, but at idle its hit or miss.
What could cause this, and how do i fix it?
Thanks!
Lamm
Old Oct 26, 2005 | 11:30 AM
snap-on's Avatar
yep mine does that, but its usually when im cruseing down the interstate, all of a sudden it jumps up like 500 rpm, then back, then up.......... then back.....
i never paid it much mind
Old Oct 26, 2005 | 11:48 AM
leiniesred's Avatar
hey snap-on, do you notice it kicks in the same place on the interstate? and at a regular interval?
I found that a radar station on a backroad that actually climbed above the belt line of the dome would put me in the line of fire for the radar beam! my tach would jump at a regular interval (every 15 seconds or so?) Spooky for the people living over there. Getting microwaved at a regular interval just can't be good for ya.
Old Oct 26, 2005 | 12:32 PM
Faded's Avatar
Mine did it for a while, and then finally died. It's been reading 0 RPMs for a while now, haven't made the time to fix it....
Old Oct 26, 2005 | 12:52 PM
Bumpin' Yota's Avatar
Anything above about 145dB in bass send my tack and speedo into siezures....lol
Old Oct 28, 2005 | 02:59 PM
4x4Lamm's Avatar
BUMP, its driving me nuts.
Lamm
Old Oct 28, 2005 | 07:24 PM
Blair's Avatar
Mine is hyperactive...reads about double the actual value. I still haven't figured it out. I just shift by ear.
Old Oct 28, 2005 | 10:27 PM
4x4Lamm's Avatar
My new runner is an auto so its not a huge problem, but it just bothers me, a lot.
Lamm
Old Oct 28, 2005 | 10:47 PM
CoedNaked's Avatar
Anytime I turn up the stereo (and I don't have a boom system or anything - I think due to the wiring) my speedometer bounces a little bit. Not a ton but enough to notice. If I turn it down it goes back to being the smooth speedometer it was. Weird.
Old Oct 28, 2005 | 10:49 PM
4x4Lamm's Avatar
Its strange because the only time any gauge acted up in my 92 was right after a 4' water crossing. And it had twice as many miles on it...
Lamm
Old Jan 30, 2006 | 08:29 AM
TexJJ's Avatar
So I am getting a vey similar problem with my tach running from 3k to 4k while holding a constant speed. I am thinking this is related to the sudden stumble that occurs randomly. Any ideas? Could it be tied in to the pick up on the distributor? Any solutions or comments out there?
JJ
Obmi
Oct 4, 2015 11:30 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
Cycles
Sep 29, 2015 06:37 AM
oldblue
Sep 28, 2015 04:07 PM
Tcsdef
Sep 7, 2015 11:17 PM
