3.0L: 2.25" Mandrel bend vs. 2.5" Crush bent?
Old Sep 27, 2005 | 07:30 PM
Randomness's Avatar
My question is this:
On the 3.0, does it make a difference in exhaust flow, or actual Internal Diameter if the pipe is crush bent, or mandrel bent?
Would I still loose too much power with a 2.5" crush bent exhaust, or does the crimping in the bends effectively lower the ID?
Thanks guys!
Old Sep 27, 2005 | 09:53 PM
Elton's Avatar
http://www.bobsmuffler.com/muffler_myths.htm
Old Sep 28, 2005 | 05:40 AM
MTL_4runner's Avatar
Thanks guys!
I'd take 2.25" mandrel bent over 2.5" crush bent any day of the week.
Crush bent pipe has awful exhaust flow characteristics.
Old Sep 28, 2005 | 05:53 AM
nrgetic99's Avatar
Which begs the question, is there a 2.25" mandrel bent system available for the 3 slow ?
I have not found one yet...
David
Old Sep 28, 2005 | 06:15 AM
DH6twinotter's Avatar
David
I went to a local shop and they quoted me $175 for a 2.25" system with a flowmaster (back when I wanted one) and a chrome tip. Another $100 for a dual exhaust. You may just have to get it custom made.
Old Sep 28, 2005 | 02:59 PM
Randomness's Avatar
I'm pretty sure there's some mandrel bent systems. I believe the Jardine system is mandrel?
And I know crush bent doesn't flow as well, but the 3.0 probably won't gain much, if any power, from any kind of exhaust work, whether mandrel or crush. Also, knowing that crush doesn't flow as well, would it alleviate that at all going with a larger than normal size (ie 2.5" over 2.25")?
Thanks!
Old Sep 29, 2005 | 09:11 AM
sandcrawler's Avatar
i've looked too, but no luck on a 2.25" mandrel bend exhaust kit for the 3.0 as far as i can tell...
personally, i'm going the custom route.
Old Sep 29, 2005 | 11:04 AM
JL8Jeff's Avatar
Jardine has a 2.25" mandrel bent exhaust cat-back system. I have it on my 88 and I'm pretty sure they make it for the 2nd gen as well. Performance Products sell it and when they run a 10% off special it's not too bad of a price.
ashamsuddin
17
Jul 22, 2024 03:59 AM
stanz
Oct 30, 2015 10:33 AM
mreagen
Oct 5, 2015 04:27 PM
mxdw88
Sep 20, 2015 03:13 AM
94toyy
12
Sep 14, 2015 06:18 AM
