synthetic oil???
I ran Mobil-1 in my 3.0 when I had it. Mine had about 180,000 km on it when I started using the Mobil-1 and it actually reduced my oil consumption. I used the Higher Mileage 10W30 grade.
i wanted to run Mobil 1 Synthetic but my t4r leaks a little. i just stick with the Mobil 1 Clean High Mileage Oil. i might go sythetic blend for a while then switch to synthetic. if it leaks more i'll just stay with what i usually use.
Go ahead and swithch it, you should be fine. If regular oil doesn't leak in it then you should be fine, anymore questions then go to Bob is the oil guy I've been running M1 in mine ever since I got my 4Runner and go for 6,000 miles before changing it, but changing the oil filter at 3k.
good news guys! lol im switching to M1 Synthetic. i checked where the leak was coming from and it wasn't from the engine. it came from the transmission. might be the gasket from the last tranny fluid change.
A friend of mine brought up what seems to be a good point about switching to synthetic on a high mileage engine. Lemme run this past you guys, and you tell me if it sounds like it holds water to you.
He said that over time, many seals will start to erode, and that normal engine oil will often get into that hold and kind of gum up, sealing it. Then, you switch to synthetic, which cleans better, and it can remove that gummed up oil, exposing the leak that was really there all along, but clogged. Sounds logical to me, but have any of you seen or heard of this happening? If so, I may replace the seals on mine before switching. Thanks.
Robert
Robert
This is probably a fluke occurance, but before I changed to synth the truck was up on a hoist, and I noticed a leak from the rear of the engine. The mech agreed with me thinking it could be rear seal ( sigh ). But after the oil change there's no more leaking. Kind of contradicts what you were saying 91T4R, but who knows...
Robert
Robert
Originally Posted by sandcrawler
since your engine only has 40k on it i'm sure you're fine switching to synth. though i hear a lot of people recommend something other than mobil 1.
Originally Posted by DaveInDenver
[...]It's sort of important to say, though, that if the seal is marginal and the only reason it's not leaking is it's clogged with gunk, it's really already gone bad.
Robert
Originally Posted by yarmish
i see some guys are using 0w40..should i stick with 10w30?
i like mobil high mileage synthetic blend personally. way cheaper than pure synthetic, but seems to clean better than regular dino juice.
switched to it from dino juice at about 85,000 miles...did not cause any leaks.
Toyvana
Jul 29, 2015 10:47 PM
yourrealdad
Jul 29, 2015 11:08 AM
