tighten throttle cable on 1st gen
Old Aug 16, 2005 | 10:06 PM
Chapman88SR5's Avatar
can someone show me how to tighten the throttle cable on a first gen 22re? picture would be nice too
Old Aug 16, 2005 | 10:18 PM
4Crawler's Avatar
Pretty simple (22RE engine assumed), about like adjusting a brake cable on a bicycle. You have the threaded ferrule that the cable passes through in a slot in the throttle mechanism. A nut on each side holds it in place. To tighten, you want to screw the ferrule back away from the throttle linkage. To do so, loosen the forward nut and screw it forward a few turns. Then turn back nut to "tighten" it. This will pull the ferrule into the nut and tighten the cable. Once set to where you want it, tighten the forward nut (holding the rear nut) to hold it in place.
Old Aug 16, 2005 | 10:24 PM
alright thanks ill try this tomorrow
kazuya2416
Apr 5, 2024 02:17 AM
vanion2
Jul 29, 2015 06:17 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
noahstancik
Jul 17, 2015 05:38 PM
rbh261
Jul 13, 2015 12:04 PM
