Press the Brake--> I go left?
Let me say, i have done no search on this so if I repeat you can beat me up
Done so far:
1: Replaced Rt caliper and pads, filled brake res.
Still did it
2: Replace left Caliper
Still did it
3: Replace brake lines
Still does it
Please help------>92 3.0
Done so far:
Still did it
Still did it
Still does it
Here you go: https://www.yotatech.com/forums/show...ght=brake+left
Next time use the search button...
usually pulling to the right or left during breaking is a sign of bad alignment.
I used to have this problem often in my Jeep since I offroaded it so often. Every once in a while I would goto an empty parking lot get upto 40 mph take my hands off the wheel and press the brake. If it stayed straight it was still good.
It could also be something to do with the brakes. When you removed the pads did either look less worn then the other?
Make sure both tires are inflated to the same PSI as well.
When you want to brake you push BOTH rudder pedals at the same time...
Oh whoops...wrong forum...
LOL
ground school day 1
zz_denis
Sep 6, 2015 03:43 PM
left is this <--- way
