Press the Brake--> I go left?
Old Jun 28, 2005 | 08:53 AM
Jays4Runnin's Avatar
Let me say, i have done no search on this so if I repeat you can beat me up
Done so far:
1: Replaced Rt caliper and pads, filled brake res.
Still did it
2: Replace left Caliper
Still did it
3: Replace brake lines
Still does it
Please help------>92 3.0
Old Jun 28, 2005 | 09:26 AM
984runner's Avatar
Here you go: https://www.yotatech.com/forums/show...ght=brake+left
Next time use the search button...
Old Jun 28, 2005 | 09:31 AM
One More Time's Avatar
left is this <--- way
Old Jun 28, 2005 | 10:40 AM
CynicX's Avatar
usually pulling to the right or left during breaking is a sign of bad alignment.
I used to have this problem often in my Jeep since I offroaded it so often. Every once in a while I would goto an empty parking lot get upto 40 mph take my hands off the wheel and press the brake. If it stayed straight it was still good.
It could also be something to do with the brakes. When you removed the pads did either look less worn then the other?
Make sure both tires are inflated to the same PSI as well.
Old Jun 28, 2005 | 11:28 AM
Sorry it also got an alignment
Old Jun 28, 2005 | 11:43 AM
4Hummer's Avatar
Master or Flex lines could be shot (the rubber line that goes from the caliper to the hard line)
Old Jun 28, 2005 | 03:24 PM
waskillywabbit's Avatar
If you just had work done...take it back and let them figure it out since it didn't do that before.
Old Jun 28, 2005 | 06:01 PM
Airborne11B's Avatar
When you want to brake you push BOTH rudder pedals at the same time...
Oh whoops...wrong forum...
Old Jun 29, 2005 | 02:43 AM
dragon564's Avatar
LOL
ground school day 1
imhousing
Sep 10, 2015 02:04 PM
zz_denis
Sep 6, 2015 03:43 PM
some drunk guy
Sep 4, 2015 11:55 PM
Squigglez
Sep 4, 2015 07:33 AM
