Did I break my CV? (pics)
Old May 19, 2005 | 02:22 AM
ColdBlueIce41's Avatar
Hey guys, my axle popped out the other day when I was doing some crawling and I'm not sure whether or not its broken.
Old May 19, 2005 | 11:40 AM
anybody?
Old May 19, 2005 | 11:42 AM
sschaefer3's Avatar
YES it is most certainly broken. More than likely from too much droop and it bound.
I had the same thing happen to me.
Old May 19, 2005 | 11:47 AM
Yeah, thats what I figured. I just put on my lift the other week, and sure enough it broke while i was out there. I'm gonna run my autozone tomorrow and get a new one. I installed your diff. drop when I put the lift on, is there anything else I can do to prevent one from breaking in the future?
Old May 19, 2005 | 11:58 AM
sschaefer3's Avatar
What lift did you use up front?
A front locker can help and hurt, but what happened to you looks exaclty like what happened to me in Moab on Rocker Knocker.
The wheels were fully turned to the left and the right front tire was drooped all the way down, it was too much with the wheels turned so hard and the outter CV just seperated, just like yours.
CV's that fail from impact typically explode the outter cup, I came up with the front limiting staps so I could set the droop where I wanted it.
Old May 19, 2005 | 12:26 PM
I used the TRD tundra lift in the front and its not locked. What you described there is exactly what happened to me.
Old May 19, 2005 | 01:51 PM
sschaefer3's Avatar
Yeah, I think you need the straps and you'll be set. Especially if you used the OME front shocks, those are considerably longer than the rest, but have the nice huge shaft and softer valveing.
Old May 20, 2005 | 06:22 AM
TStango's Avatar
I think I need limit straps too.
I recently replaced by driverside CV shaft with a new one from NAPA. When I put the tire back on, I gave it a turn and noticed the CV joints are binding. This is with the wheel off the ground, suspension at full droop. The entire front diff lurches when I cycle(force) the wheel one rev.
Old May 20, 2005 | 06:41 AM
sschaefer3's Avatar
There is such a thing as too much droop. A tire hanging there with no weight on it is not going to act like a drooped tire on a straight axle.
Run a front locker, keep your front travel within reason and don't get on the gas.
My axle from Moab:
Hunt's axle from Moab:
We both broke at the same place, no one else with IFS even tried it.
This is the reason along with the fact "I could", that I converted to the Dana 44. It broke too easily with that extra droop.
Binding breaks pull the tulip apart, get on the gas breaks typically blow the outter shell apart.
Know your travel and limit it within reason. They only build so_much_droop into these parts.
Old May 20, 2005 | 07:06 AM
FilthyRich's Avatar
Steve's brackets/ kit is NIIIICE I bought his setup and it is awesome. I like the prerunner/ long travel look too.
Old May 20, 2005 | 04:31 PM
Bighead's Avatar
I was wondering what Hunt's axle looked like after it blew on Pritchett. For some reason that is the first pic I had seen of it.
Old May 20, 2005 | 04:45 PM
sschaefer3's Avatar
It's on the DVD you have.
Old May 21, 2005 | 01:46 AM
Bighead's Avatar
Apparently I need to dig around in that more.
Old May 21, 2005 | 05:48 AM
sschaefer3's Avatar
It's all in this sub-folder:
2004_10_09 M4R4A Pritchett Canyon
okamikai
Apr 30, 2018 10:19 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
CanRunner
Jul 20, 2015 01:29 PM
colasurdo
Jul 16, 2015 11:37 AM
