Low compression
Old May 4, 2005 | 08:22 AM
mrmojorisinphan's Avatar
Low compression
hey everyone,
I'm looking into buying a 89 toy p/u 3.0l v6.
It has low compression, so the price is ridiculously cheap.
what exactly could be causing the low compression? I just want to know what I'm getting into if i do purchase it. Does it need new HG, or is it something more serious.
I may just try to find a remanufactured engine to throw in there..
any help is appreciated
tre
Old May 4, 2005 | 12:24 PM
eric-the-red's Avatar
How low is low, and on which cylinders. If it's low on 2 joining cylinders and OK on the rest then that's probably a head gasket. If all of them are low then your looking at worn rings. Even if it's a head gasket on a 89 you may want to do a valve job while the heads are off, so that will add to the cost.
Old May 4, 2005 | 01:49 PM
Cool, thanks for the info. I'm going to be running a compression check on it tonight to see what cylinders are bad...
Old May 4, 2005 | 04:15 PM
wimpywade94's Avatar
post up what you find to.
my #'s were around 172,165,162,160 starting from the front to the rear.
those arent low are they? its a 22re with a 1/4 million on her almost, well, 223000,
wade
Old May 4, 2005 | 05:36 PM
CynicX's Avatar
wade
they arent low...but all cylinders have should have a certain % difference...and the difference between 172 and 160 is really gonna be pushing it....I dunno what that % is, you may be able to check the service manual about this....
Old May 4, 2005 | 06:05 PM
Glenn's Avatar
160 and 172 are only about 7% apart, so it should be OK.
Sleaker
Aug 26, 2020 06:03 AM
RatOmeter
Oct 22, 2015 03:17 PM
justdifferentials
Just Differentials
Sep 8, 2015 03:15 PM
justdifferentials
Sep 8, 2015 03:13 PM
Sidherish
Aug 2, 2015 01:42 PM
