Dropped Drive Axle doing 70!!
The most exciting part was that it was the front universal that went out, so my truck used my axle as a freakin pole vault!
I was able to keep control and pulled off the road. Now I have it back home, but now what!?
The Hanes manual gives instructions on removal and installation, but what if the thing is half removed already? It keeps telling me to mark the flanges so I know where to line it up to, but if it has been free spinning a bit, how do I know what wen where?
Also what do I need to replace? I know I will have to replace the front Universal, but what about the Drive shaft itself? Do I have it checked and balanced? Replace it?
Any ideas on this will help, guys. Thanks in advance!
I would bring it to a driveshaft shop and at least have it inspected. Would probably replace it myself if it did "pole vault"
I would just find one at a junk yard and pull the whole thing off and put it in yours. I am in the process of replacing the all the u-joints in mine, so with the added expense of taking it to a shop, you could probably pick one up for just as much and not have to do anything but bolt it on.
Aahahahha, i was just watching a show called mythbusters where they did the exact same experiment!
They were going pretty slow (40-50k) and it really messed up the car, i would check everything for the alignment of your rearend/frame and suspension, ot see it it's still straight (if the truck did indeed pole vault).
Oh, new driveshaft for sure.
Roger's site will help you a lot with the phasing and other details: http://www.4crawler.com/4x4/CheapTri...line-101.shtml
All great comments so far guys. I like the idea of the junk yard, but how do I know if it is good? I still may do that though. I have a local drive shaft shop that I could call, but I am sure that is going to start to cost a bit. Money no object in getting it done, but I still don't want to have to fork out what I don't have to. I will get the alignment done, regardless.
if you pole vaulted off your front drive shaft, make sure you T-case isn't damaged and that the flange is still tight..
I think the transfer case was not effected, but I will double check. The scary thing is it almost took out my catalytic converter that I just had replaced by warrenty last Friday! The heat shield is a bit banged up, though. I will get some pictures posted a little later...
Keep the informative replies coming!
It seams very suspicious that you had the catalytic converter just replaced by warranty last Friday and now your front drive shaft falls off… They may have taken it off for more room to work and forgot to tighten the bolts back up. Just a thought…
I would think your drive shaft is most likely junk now. Also look closely at the t-case flange and seal, is it leaking any oil?
I found a rear drive axle assembly for $150 at a local yard. I think I may snag that one and check the angles when I install this one.
I will double check the transfer case as I recall there was no real damage to it, but it was a bit oily.
As for the the installation of the catalytic converter, I was under the car with him when he did it. It wasn't anything he did.
It should be bone dry. If there is oil on it (not road grime) then you have a problem. Hopefully its just a worn seal or loose pinion nut.
Was it the front driveshaft or the rear driveshaft? We are parting out a 90 runner with auto, rear drive shaft $50 (plus shipping from Seattle). Not sure if yours is the same.
Originally Posted by rngrchad
because I don't trust mechanics.
Update
I got the used axle for $150 here locally and bolted it in. It worked perfect. The only problem that still remains is a weep that started from the oil seal in the front of the differential. I left my truck at home today and barrowed a car for the day. I will pick up the seal and put it in tonight, but I thin all is well beside that. It didn't even feel to be out of alignment, but I will probably be getting that done anyways.
Thanks for the input guys!
Originally Posted by mt_goat
How often did you grease your u-joints? Maybe the bearings seized up.
