1997 4 Runner Rear Axle Problem,,,locker Recommendations?
Old Apr 13, 2005 | 10:01 AM
BOSTON4RUNNER's Avatar
1997 4Runner SR5 5 Speed 3.4 liter......
seems I need right rear axle bearings, checked the brakes last night and they were mint
sounds like I have a wounded grizzly bear in the back seat
metal to metal type sound....did some searches seems that my hunch of axle bearings seems to be the issue
while it is apart, I will toss a locker in my rear end, or whatever rear end I get for a replacement
any recommendations on where to buy a locker and how much they are? also what should I be paying for a good used rear end from a salvage yard...and yes I know to make sure to get the correct gears etc
thanks in advance, tim
Old Apr 13, 2005 | 10:36 AM
rimpainter.com's Avatar
How many miles do you have? Have you had your premonition confirmed by an expert?
I think the best and easiest way to get a locker is to find the entire housing from a wrecked 4Runner (make sure there was no damage to the axle) with the same ratio and just swap the entire thing in. It really wasn't that hard. I did it with hand tools in a 110 degree garage. The front diff, now that's a different story.
Old Apr 13, 2005 | 11:14 AM
I build and race cars as a hobby not that I am an expert but was a mechanic for 6 years at a high performance shop,,,I am going to check it out further tonight
seems like axle bearings
there is 220k on it
I also think best will be to swap in another axle, change the fluid throw the locker in etc etc
Old Apr 13, 2005 | 11:58 AM
summit has the powertrax in stock
260 bucks which includes next day air shipping
Old Apr 13, 2005 | 01:14 PM
westy44runner's Avatar
if you need an entire new rear axle or are committed to going that route...why not just get another toyota rear end with the e-locker?
Old Apr 13, 2005 | 02:12 PM
wll a TRD from a taco fit my truck
any of them come with 410s?
my truck has 410's
Old Apr 13, 2005 | 04:43 PM
Plan B
tomorrow night disassemble, inspect, then replace all bearings and given that the third member is good, throw in the powertrax,,,reinstall
what you think?
Old Apr 13, 2005 | 08:30 PM
deathrunner's Avatar
sounds good, but if you want a selectable locker, just find a yota 3rd member with the e-locker. very cool and it will easily fit your vehichle.
Old Apr 14, 2005 | 04:37 AM
the problem is,,,,all of the e lockers came with 430s correct?
or could you get them with 410s in a taco...problem is in the northeast, due to winters here, i think those are pretty sought after and tough to find, i need to get my truck back together quick
tonight i am pulling the axles and third member out
6th Gear
19
Dec 10, 2019 07:31 AM
4x4-runner
Feb 26, 2017 06:42 AM
cchinny
Jun 25, 2015 08:11 PM
Niameyrider
Jun 25, 2015 05:50 AM
Leonel
Jun 13, 2002 02:42 PM
