Problems with electric door locks...
In the last three weeks I have been having intermittant problems with my electric door locks. Every now and then the locks will "jump" to the unlock position (if they were locked). If I try and lock the doors with the switch, the locks will lock then unlock right away. Sometimes, when I start the 4Runner, the automatic locks will lock then pop back up.
Then, after a while with this behavior, it will start working fine. Any ideas what could be the problem?
maybe the door pin switch? You cant lock the doors using the switch if it senses the door is open, are your dome lights turning on by themselves? Could also be a problem with an alarm if you have one, as it automatically locks and unlocks as you start the car/turn off the car.
try checking the "body ecu" fuse, I think thats what its called. Ill check later today. It might have a loose wire or fuse. When I installed my remote start, I realized that that fuse controls the automatic door locks, and windows. When that fuse is disconnected, the doors unlock, reconnected, the doors lock, so maybe something is going on there. Check all the connections to the alarm and in the interior fuse box.
The fuse is located under the dashboard. This problem probably does not have anything to do with the remote start, unless you hooked it up to work the locks too. Then there might be a problem with the remote start. I just figured out how the alarm/door locks worked on the 4runner when I installed my remote start. If all else fails, disconnect the remote start and see if you still have problems.
I checked, the fuse is ECU IG, top left. when 12 volts is powering that circuit, the door locks automatically lock, and the keyless entry does not work. When 12 volts is removed, as in a loose wire, the door locks will unlock(only if previously automatically locked) and the keyless entry will work again. If this is not the problem, I would think it is a loose ground somewhere.
I'm thinking you got a bad relay, the "lock" portion of it is always on, an electromagnet gone bad. depending on your year, either I think you need a new relay or a new door lock control unit/relay
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
Sep 9, 2015 06:24 AM
v_man
Jul 23, 2015 04:01 PM
Poncho0206
Jul 10, 2015 06:21 PM
WTB[PacSoWest]: Looking for a electric locking differential motor/ actuator
AaronM
Jul 8, 2015 07:15 PM
