22re timing chain replacement
Old Apr 10, 2005 | 10:39 AM
needayota's Avatar
hey all,
i put the front timing chain assembly together (the tensioner, both guides and the sprocket for the crank shaft) so right now i put the head on and the piston is at tdc. im trying to put the chain and camshaft sprocket on the cam shaft but it just wont budge. ive tried turning the crank to give me more chain and that didnt work. so what is the best way to go about doing this?
thanks guys,
Old Apr 10, 2005 | 11:02 AM
4Crawler's Avatar
I found I had to remove one or both of the chain guides to get enough slack in my chain to get in into place on the camshaft.
Old Apr 10, 2005 | 12:24 PM
Brendan's Avatar
i think i used a rubber hammer, but there is a better method i'm sure.
Old Jun 7, 2005 | 10:46 PM
Dezertoyota's Avatar
Can't you push the tensioner in to give you more slack to get the spocket on the end of the cam??
Old Jun 13, 2005 | 11:46 PM
miket223's Avatar
It helps to reach down there with a large breaker bar or long stick of metal to pry the tensioner back in and then you'll have just enough slack to slip the cam sprocket on.
Old Jun 14, 2005 | 07:30 AM
SteamedHomer's Avatar
You have to push back the tensioner. When I replaced mine I wedged a small block of wood with a string attached to keep the tensioner pushed back. After the sprocket is attached to the cam just pull the string and the wedge will come out.
Old Jun 14, 2005 | 07:50 AM
kyle_22r's Avatar
the way i get my cam sprocket on(no way i can put it on by hand) is to stick a small prybar in one of the holes, rest the angled part on the camshaft, and walk it up onto the cam
fasterspider
Oct 6, 2015 10:24 AM
Ichneumon
Sep 27, 2015 04:21 PM
Badger62811
Jun 26, 2015 09:26 PM
Taz22R
Jun 21, 2015 04:44 PM
paxanders
Jun 21, 2015 06:29 AM
