How does this sound for shocks?
Old Apr 6, 2005 | 09:40 AM
Extremesolo's Avatar
BJ spacers, Chevy swap, u-bolt flip, shocks in stock location - rear Bilstein BE 56250H5 20.75" compressed, 34.91" extended, 14.31" travel. Front - Bilstein BE 56582H5 11.67" compressed, 17.95" extended, 6.28" travel. I am concerned about the compressed lengths being too long and not allowing the tires to be stuffed without running out of room in the shock and damaging the shocks. I have not ordered these yet but I need to very soon. I came up with these numbers from a cross from rancho 5012 and 5167 shocks which were recommended by some others who had a similar setup. I need help with this please let me know if you think this will work.
Old Apr 6, 2005 | 11:31 AM
mastacox's Avatar
It's hard to say whether they will work or not, your best bet is to measure your own truck from mount to mount and find out... Check extended and compressed values and see...
Old Apr 6, 2005 | 11:54 AM
seaflea's Avatar
The rear shocks may be too tall for the stock location. you may want to mount them in a / \ . Like Brian said, its best to measure and then decide. also talk to others that have the same setup and see exactly what they are running.
Old Apr 6, 2005 | 01:00 PM
I have been trying to obtain this info for several days. I know it is a fairly common setup but no one seems to be able to give me their sizes. I have not installed this yet but I wanted to have everything ready to assemble at once so I have minimal downtime with my runner. Please keep the replies coming.
Old Apr 6, 2005 | 02:04 PM
westy44runner's Avatar
those shocks may be alittle long...i know 14" travel bils barely fit on my 86 rear with 5" Alcans and LOTS of travel...i dont know how much lift you will get with the chevys..? if you mount them through the bed or fab a custom mount they will work however. mounting them in an / \ pattern also allows the use of longer shocks and more travel but it compromises shock performance also and leads to more body roll.
good luck...
Brian
runneroffroad
Sep 5, 2015 07:02 AM
mistershmi
Aug 31, 2015 03:44 PM
kpnalder1
Aug 31, 2015 05:01 AM
punks_is_4x4
Aug 21, 2015 01:35 PM
SMOD
Jul 27, 2015 01:45 PM
