Tundra coils DON'T fit 95-97 Tacos!
(This is also posted in the general tech section, in case you are feeling a sense of deja-vu).
Okay, It looks as though Tundra coils WILL NOT fit on a 97 Tacoma (therefore 95.5-97 I imagine). I put together the exact setup outlined by bamachem (not blaming him by the way) as far as TRD Tundra Coils, his spacers, and in this case, OME N91S shocks. As far as I can tell, the stud spacing is wider by about 1/8" of an inch on the Tundra Coils. Additionally the top-plate is noticeably wider (as are the spacers) then the one on my stock coils (Tokico's).
NOW, if I'm mistaken, or there's some trick to making them fit that I haven't discovered, then please let me know.
I know folks with new tacomas run this successfully, so just those of us with the first few years are out of luck.
Needless to say, watch the classifieds for the above suspension setup.
I'm off to drown my sorrows.......
:cry:
:cry:
:cry:
:cry:
Originally Posted by superjoe83
are you trying to use the tundra top plate, because like you said the bolt holes are in a bigger pattern, did you try to use the taco top plate on the tundra springs?
Thanks,Ian
I have a set of his spacers sitting at my house and i will measure them when i get home this afternoon to tell you the hole distance. I have a 97 runner and the set up fits on mine and im going to run two spacers.
eric
eric
Originally Posted by Ehinfinity
Upside down jack on the upper a-arm and the biggest hammer you can find j/k.
everything should go in fine.
eric
everything should go in fine.eric
Originally Posted by Bighead
Did you disconnect the 4 bolts that connect the lower balljoint?
Originally Posted by ianshoots
Tried that, seemed as though the upper arm was hitting the coil and I still couldn't get it to line up at the bottom. Gonna wait for Andy to send my second set of spacers, then try again.
you'll probally be at 3" or MORE w/ a second set on an early taco...
Bighead, yep thats what he told me. I might just have to give it a try today (the upside to unemployment).
Andy, I figure that I should just keep them on hand; I might not need them right away, but It seems pretty likely that I'll gain weight in the front in the relatively near future. In the back I'm gonna wind up at 2.75" (before I load up) and I want to be able to keep things fairly level. If one spacer puts me at 2.5" in front than I'll stay with that for the time being.
No back the real challenge-the rear leaves, talk about massive seizure.
From: raleigh, nc for school chapel hill, nc for home
or "TUNDRA TRD lift"
https://www.yotatech.com/search.php?searchid=2314872
or "sonoran steel lift"
https://www.yotatech.com/search.php?searchid=2314920
and you'd get THIS:
https://www.yotatech.com/forums/f2/new-suspension-setup-trd-front-lift-3rd-gen-4runner-41848/
and you'd get THIS:
Jun 1, 2021 01:51 PM
sandyota
Feb 4, 2021 11:16 AM
crashburnoveride
Jul 10, 2015 06:39 AM
Suprarossa
Jul 6, 2015 05:21 AM
Vargntucson
Jul 4, 2015 12:15 PM
