Need help with my front brakes...
Old Jan 19, 2003 | 05:27 AM
UKMyers's Avatar
Okay okay so I am still learning the ropes on my Runner. I tried to change out my front pads yesterday with no luck. I could not get the two pins that hold the pads in out. They were super duper dry and I was afraid to spray anything on them for fear of getting it in the caliper, on the rotor ect. I got one part way out with some vise grips by turning it back and forth while pulling. Is there a special trick to doing this little project or does it just take persistence and patience? I didn't try super hard because it was getting late and I didn't really want to screw something up. Can someone point me down the road I need to take to get these suckers changed? I would just pay to have it done but I know it's not that hard to do.. Here's a pic of the pins that you can reference off of..thanks
BTW it doesn't show in the pic but I did remove the spring that goes through the holes on the backside of the pins.
Old Jan 19, 2003 | 10:33 AM
oly884's Avatar
Guest
I took a small screwdriver and tapped the backside of the pins. when they started to come out I used some pliers to pull them out the rest of the way. You can spray some stuff to loosen up the pins but after you are done use some brake cleaner and spray it everywhere on the brakes. it removes all the crap that builds up, and the stuff you sprayed on.
Old Jan 19, 2003 | 10:56 AM
Arnold's Avatar
Spray everything down w/ brake cleaner. As mentioned, punch them out through the back side. A small punch works great.
Old Jan 19, 2003 | 11:27 AM
UKMyers's Avatar
Thanks for the replies.. I totally forgot about brake cleaner. I may try and tackle this next weekend.. My pads still have some life left in them but the truck pulls some when I hit the brakes that's why I want to change em out.
Old Jan 19, 2003 | 07:31 PM
williemon's Avatar
I like to use 000 steel wool to clean and polish mine up when I take them out. I also dab disk brake grease on the areas that need ti slide, such as the pins and a couple places on the caliper where the pad backing plate may contact.
Old Jan 20, 2003 | 03:36 AM
Travis's Avatar
Be careful with the anti-rattle springs when putting in new pads. They're pretty fragile I broke mine last time and the local dealer didn't have any in stock.
Everywhere I go, I hear bells.
Old Feb 9, 2003 | 10:15 AM
mark from uk's Avatar
the best thing to put them back together with is copper greese, it is specialy designed for keeping brake parts mooving
Old Feb 23, 2003 | 03:21 PM
Firefyter-Emt's Avatar
Dude.. if you are pulling, it sounds like you need a set of calipers.. not pads. I would bet one is freezing up on you..
88sasturbotoy
Jan 30, 2026 01:57 PM
Sr5crawler
Jul 31, 2015 12:32 PM
coffey50
Jul 28, 2015 10:55 AM
Steven.m.paulk
Jul 24, 2015 01:44 PM
scottyg486
Jul 19, 2015 05:34 PM
