Fuel Rail removal
Old Feb 26, 2005 | 12:09 PM
Wildcat_4R's Avatar
Fuel Rail removal
Ok, just to get things straight. The pressure regulator is located on the fuel rail, closest to the firewall. The fuel pulse thing (offical name would be appreciated) is on the end of the fuel rail closest to cylinder #1 and it is reverse threaded. None of the bolts seem to want to budge and I don't want to crank on it in the wrong direction.
Old Feb 26, 2005 | 01:25 PM
Wildcat_4R's Avatar
Anybody? My Haynes maual isn't much help. Any info on getting the rail out would be greatly appreciated.
Old Feb 26, 2005 | 03:22 PM
tanman2003's Avatar
pulsation dampener
there is a bolt connecting the fuel hose to the delivery pipe. take that off remove hose from delivery pipe. you need a pretty big wrench.
there are two bolts i think that hold the delivery pipe to the intake manifold.
Old Feb 26, 2005 | 04:07 PM
Joyota's Avatar
Are you talking about this pipe?
I don't remember anything having left-hand threads on this fuel rail.
Old Feb 26, 2005 | 04:22 PM
mt_goat's Avatar
You usually only see reverse threads on things that are spinning, like the cooling fan.
Old Feb 26, 2005 | 05:19 PM
Wildcat_4R's Avatar
Thanks for the info. I figured it out this afternoon. There is nothing on the fuel rail that has reverse threads. The bolts required a 22mm wrench and a 17mm wrench from front to back respectively.
Doug4320
Mar 24, 2018 10:11 PM
Sep 4, 2015 09:27 AM
Hiluxtrucha
Jul 22, 2015 10:00 AM
Fundy Rider
Jul 16, 2015 01:35 AM
crashburnoveride
Jul 10, 2015 06:39 AM
