Squeeling noise when driving .
Old Feb 24, 2005 | 05:06 PM
pfbmgd's Avatar
I started my runner this afternoon .As I pulled away I heard a squeeling sound .Not very loud but it is there . I stopped put it in nuetral and reved up the motor the squeeling was not there . Under power threr is no squeeling .But when I take my foot of the throtle and am rolling the squeeling is there .Any ideas .
Old Feb 24, 2005 | 11:13 PM
wrenchmonster's Avatar
What kind of squeal is it? A belt? Or coming more from the wheels? Need more information. I bet some basic investigating would reveal the problem.
-Wrench
Old Feb 24, 2005 | 11:45 PM
Poor A$$ Stock '93's Avatar
sounds like a belt. Try tightning them up a bit; if it doesn't go away buy new ones. Do both at once to save some hastle.
could be something else though I guess.
Old Feb 25, 2005 | 01:41 AM
pfbmgd's Avatar
I thought it was a belt too .But the noise goes away in nuetral.
Old Feb 25, 2005 | 02:52 AM
Tacoma Dude's Avatar
Does it matter if you're in neutral or not?
I thought it didn't...?
Old Feb 25, 2005 | 03:13 AM
ilocan's Avatar
Your rear drive shaft slip joint needs lubrication. The squeeling noise your hearing while rolling in neutral is a classic symptom.
Old Feb 25, 2005 | 03:46 AM
pfbmgd's Avatar
If I take it in to Toyota is this paert of a regular drive shaft lubrication service ?
Old Feb 25, 2005 | 07:20 AM
ColImport's Avatar
I bet it is an issue with the brakes, could be caliper not opening and it is rubbin on the rotor....just change the pads if needed and bleed the fluid.
Old Feb 25, 2005 | 07:33 AM
pfbmgd's Avatar
I was thinking the same thing .If the weather is good .I will pull the wheels to check .
Old Feb 25, 2005 | 07:37 AM
Yota4runner's Avatar
wait, didnt you say it goes away in neutral? So I think maybe it's not Your rear Dshaft slip joint. It could need lubricatrion but if the sqealing is going away in neutral its not likely to be the cause of your noise. It could be but I would look into all options before you start throwing money at it.
Check your belts, if it goes away in neutral, watch your tach, do you RPM's go up when its idleing in Neutral? as opposed to under load. Chances are it is your belts, I had the same problem not to long ago after having my belts serviced, the sqealing wasn't present when I stepped on the gas but was when I was idling. But not when I reved the engine. Try putting some soap or belt dressing on your belts, see if that helps, if not replace them and then work your way back.
Old Feb 25, 2005 | 07:48 AM
ColImport's Avatar
well I know it just happens probably with the car running....and if it is on N the car is not running. pretty sure is a caliper
Old Feb 25, 2005 | 07:50 AM
ColImport's Avatar
open your left front window then your right front when you hear the squeal and you will hear it more on either window...then you know it is coming from the wheels
mskalmus
May 28, 2017 07:51 AM
mengquis
Jul 13, 2015 10:39 AM
razorman8669
Jul 12, 2015 12:13 PM
mlavery85
Jul 12, 2015 10:33 AM
Poncho0206
Jul 10, 2015 06:21 PM
