Diff drop-how high ??
Usually recommended above 2", you can install a drop kit at 2" and below, but the biggest benefit comes above 2":
http://www.4Crawler.com/4x4/ForSale/...l#Introduction
Here is the kit I make:
http://www.4Crawler.com/4x4/ForSale/DiffDrop.shtml
Not much to the installation (instructions on-line at the page above), hardest part is dealing with the skid plates. Kit includes hardware to reattach them, the variable is how much work you need to do enlarging the holes to fit them back on. Seems to be quite a bit of variation here, some folks just bolt them back up w/ no problems, others have to spend the better part of an hour refitting the skidplates back in place.
HaveBlue posted this thread a while back on the installation: https://www.yotatech.com/forums/show...ight=Diff+Drop
Thanks dudes you guys have been very helpfull. I believe I will go with the PP1, billies which I am still wating for the rear two wich were sent incorrect from Cabe, and the 1 inch diff kit from Sonoran, just to be on the safe side.
I will also be using a 5MM trim spacer up front, would I need extended studs or would the stock ones still work??
Thanks
Thanks
priest16
15
Aug 6, 2015 07:43 AM
Luvmeye22re
Aug 4, 2015 03:53 PM
Steven.m.paulk
Jul 24, 2015 01:44 PM
scottyg486
Jul 19, 2015 05:34 PM
