Camshaft?
Old Jan 14, 2005 | 04:13 PM
YotaTruck1986's Avatar
Question Camshaft?
What do you guys think about LCEs EFI Pro Cam: (For my 22RE.)
Intake / Exhaust
Valve Lash: .008 / .012
Valve Lift: .440 / .440
Duration @ 50: 230° / 230°
Lobe Center: 102° / 118°
Lobe Separation: 110°
Intake Opens 13 ° BTDC Exhaust Opens 45 ° BBDC
intake Closes 37 ° ABDC Exhaust Closes 5 ° ATDC
Should I install new rockers with this cam? Thanks.
Old Jan 14, 2005 | 05:15 PM
Bump.
Old Jan 14, 2005 | 06:11 PM
alltrac165's Avatar
From what I gather, that long a duration will make for tricky tuning on the EFI engine. I understand that cam timing is also critical. If you have shaved the head then the cam timing gets retarded and that is supposed to be highly detrimental to power with a big cam like that so beware.
There have been some great discussions on cams over on 4x4Wire which I just got finished searching, incidentally. I am about to upgrade my cam as well. I had decided on EB's 268 cam (available at www.engnbldr.com) but he's out of stock right now and I'm in a pinch so I'll probably run the stock stick for a while.
Old Jan 14, 2005 | 09:32 PM
SoCal4Running's Avatar
Is this for a daily driver?
Old Jan 15, 2005 | 07:38 AM
Yes, it's my daily driver. I wasn't sure if this cam would be to extreme, but it's included in the LCE kit. Should I consider a more milder cam? Thanks.
Old Jan 15, 2005 | 03:30 PM
jimbo74's Avatar
will be fine... look here: this is roger browns trd cam on his 86 efi 4runner http://www.4crawler.com/4x4/CheapTri...shtml#Camshaft
Old Jan 15, 2005 | 08:05 PM
93YODER's Avatar
Thats alot of cam fer such a small motor such as the 22re.Never mind lift @440 thousands,but with that much duration,yer going to lose lots of low end torq,vacume,and it will have a poor idle.Four a daily driver i wouldnt go over about 210 degrees duration,and even less four a 4x4.
Old Jan 15, 2005 | 08:16 PM
I don't know much about cams, but on his, the intake lift is .416 vs. the LCE .440 and his exhuast lift .430 vs. the LCE .440. Would the LCE lift be harder on the 22RE? Or should I go with something less?
Does anyone have any good experience with cams for a 22RE? Thanks.
Old Jan 15, 2005 | 08:38 PM
93YODER's Avatar
As far as over all power goes, the more lift the better,but the do tend to wear the valve springs out quicker,replace the springs with some high quality aftermarket ones that can take the added lift.
Old Jan 16, 2005 | 07:37 AM
alltrac165's Avatar
www.engnbldr.com has a good choice of cams for the 22R.
See reviews about them on 4x4wire. Do a search on 22r cams on that board.
Here are the specs on the 3 22R cams he has.
All are on 110° lobe separation.
261C is 222° @ .050", 261° advertised, .410" lift.
268C/Torkr is 218° @ .050", 268° advertised, .425" lift
270/430 is 219° @ .050", . 270° advertised, .430" lift.
You'll notice that all those cams have considerably less duration than the LCE cam. Long duration is what kills your everyday driveability as mentioned by 93yoder. LCE's cam looks like it's ground with about 4* advance built in which should help with some of the low end, but still might be a little lopey for daily street use.
foampile
Dec 18, 2022 01:29 PM
kawazx636
Oct 6, 2021 03:03 PM
Obmi
Oct 30, 2015 04:27 PM
Oldmanleftear
Sep 1, 2015 04:11 AM
