Tacoma/Mini Pickup rear bumper
Originally Posted by crash
Looks like a jeep bumper
Hey Steve,
Looks good man! I was wondering if you've ever used .045 gas shielded flux core wire instead of using just standard mig gas wire? I just bought the powermig 215 yesterday, and it claims using this combination it will weld up to 1/2" thick. And another guys has mentioned that the combination flux core and 75/25 gas creates and extremely pretty weld too. Any comments?
Chris
Chris
Originally Posted by ravencr
Hey Steve,
Chris
Chris
First off.
Flux core is cool, and serves a purpose. Flux core indeed does penetrate deeper assuming similar amperages. For this reason only I recommend to users of 125-140 amp(120V) mig machines to use this wire when welding over 10+ gauge materials.
Flux core wire itself has limitations on material thickness. I belive that Lincolns NR211mp is 3/8 for both .035 & .045 . This is most likely the only flux core wire you might ever use in a PM 215.
NEVER use gas when using a NON dual sheild wire. So basically dont just add gas to a self sheilding flux core wire- thats not acceptable. There are wires meant for using gas that do have a core to them, and they are called "cored wire" or "dual sheild". These wires are very expensive, and really only used on thick materials. More than likely you will never have a reason to ever use this wire. Personally I have only used this type of wire for one three month long job which required us to put softball sized forgings onto three inch thick plate!!! Thats definately rare, and I have been in business for almost eight years(granted we have been out of heavy industrial for just over two).
Now a wire like the normal common flux core I use semi often basically depends on where you are working. In the wind?-flux core Around dirt & grease(clean up I know-just an example) flux core again.
I say buy a 33-45 lbs spool of hardwire (er70s-6), and a ten lb spool of Lincolns NR211-mp you will use them both. There is alot more I could say about the hardwire (like its naturally low hydrogen, has excellent elongation properties, high tensile strength etc) but I need to go to bed!!! If you have any real specific questions you are always welcome to email me.
Take care,
Richard Stubbs
.035 & .045 thickness limit 5/16"
.068 & 5/64 & 3/32 thickness limit 1/2" these wire sizes are too big for your machine.
Go to this link, and look at page 14. All you need to know about flux core wires!
http://content.lincolnelectric.com/p...ure/c32000.pdf
Oh, and Steve nicely done as per usual!!!
Thanks for the info guys. I put it all together last night, and found out that the spindle requires a large spool, and doesn't come with an adapter for the 11 lb spools, so I'm going to get a 44lb spool today that should fit. Richard, I might email sometime, and I appreciate the offer.
Chris
Chris
Originally Posted by TacomaTRD
got a pic of it on a truck, I maybe interested in one... How much does it weigh vs stock? I would like to add a bit more wieght for a better ride.
I can weigh it.
Finally hooked up with the customer and it's done. No way this can be a pre-made ship to a truck sight unseen product. The rear license plate panel needs to have specific shaped slots plasma cut into it for the bumper to sit nice and high like this.
I could build the beam and the brackets and you could finish it on site, but realistically that is not going to sell. More or less a fully custom rear bumper.
Price for an in town install would be $500 unpainted. You get what you pay for. This this is a tank and fits like a glove.
Now if a Tacoma does not have that panel that the 95 and older Mini PU does, that's a different story...........
